Window clasp question
This came off.  I think it was just glued in, but I’m not sure.  It may have broken off.  I can’t tell by looking at the others.  Thoughts?
Thanks!
    Call Elsie in the Parts dept. at nuCamp.  A common replacement item.  She will mail them out.  I think the factory is closed this week, so be patient.
  • LauraRey
    LauraRey Member Posts: 338
    So is it actually broken or just unglued?
  • dragonsdofly
    @LauraRey, it was never glued. It just clips on. If it is still intact, and doesn't have a broken edge, you can snap it back on. Otherwise, what @SAM said.
    ScottG Administrator Posts: 5,693
    Since it's already off, throw it out. Opposable thumbs do the same thing!  ;-)
  • ericnliz
    ericnliz Member Posts: 4,437
    Clips right back on if the clips are still intact. I've had to clip mine back on a couple of times.
  • LauraRey
    What? You didn't find my response helpful?  :-) :-) :-)
    Seriously, since my vintage didn't come with those clips, what do those of you that have them do when you want to adjust your windows from the inside? Do you have to unclip and reclip every time?
    Do the shades and screens not stay together without the clip? I'm honestly curious about what purpose these things actually serve! Am I missing something here?
    The clips bring the upper screen and the lower shade together securely.  It allows you to move them both up or down at the same time.  It is easy to unclip and move the screens up and the shades down to access the window supports.
