I know this was posted in another discussion, but I can't seem to find it. Getting closer to purchasing a 320S Boondock. My tow vehicle will be a 2014 Jeep Wrangler Unlimited (4dr). Of course, I will need an entire tow package installed on the jeep. I have a quote that has the following:
Hitch (2 inch REC)
OEM Signal Wire Kit
Installation of electric brake control wiring (includes all additional parts and PILOT digital controller)
Class 3 Ball mount
2” Chrome Ball
Pin and clip
What am I missing?
British Columbia, Canada
Adventures: 51 Nights: 322 Towing Miles 41,200+
I will have to check - but my Jeep is an automatic, and am reading online that they already have one installed. I will have to take a closer look through the grill to make sure. - Good point though.
Alan & Patty
Southern Az
Re: brake controller - after reading many discussions here and reviews on the web we decided to use an Autowbrake brake controller. It is wireless and requires nothing in the TV. The "wired" controllers require a connection to the brake light switch under the dash and a wire running back to the 7 pin. The Autowbrake is basically a tiny computer attached to the T@B wired into the T@B junction box (on the front of the frame behind the LP tank and battery). When the T@B brake lights turn on the acceleration/deceleration sensors and logic on the Autowbrake determine how much "pressure" to apply to the trailer brakes (it's a proportional controller). It's only wireless in the sense that there are no wires from it to the TV. There is however, a little remote button that allows you to test and adjust the sensitivity of the brakes and allows you to "tap" only the trailer brakes to dampen any fishtailing or other misbehavior. It is elegant, but pricey ($349) info at https://getautowbrake.com/
