Keder Rail length
Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,015
Does anyone know off hand the keder rail length on the CS driver side?  I am purchasing a shade cloth.
Sharon
  • mannymanny Member Posts: 108
    @sam   15' ft. 4 " in  from the top of the pull handle to the back.  I hope this helps...
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,015
    Thanks Manny!  I hate having to store our Tab off site.  Some day it will be housed with us.  Sigh.  I ordered an 8 x 10.  That should stretch from the handle to the hinge of the hatch and shade the driver’s side and AC.
    Smart idea @SAM! I'd be very lost if Bug was offsite and I couldn't go hide out, play with mods and daydream! How will you secure it out from your Tab?
    @sam I have a 8' ft. garage door.. she sits nice and cozy inside..   Of course its 95 deg. down here in s.w. Ohio   try to stay cool...
    @manny, I’m jealous, but it only hit 94 today in NE Ohio!😅. Ditto - stay inside.
    @Homebodyatheart, the setup I ordered from Amazon comes with keder rail attachments with hooks (?correct size for the rail?), ball bungees, stakes, and grommets every 1.5 feet.  We plan to attach it to the driver side keder rail and stake it to the ground 4 feet from the Tab using the stakes and cording as needed.  The hypotenuse of the triangle was just over 8 feet, so I ordered an 8 x 10.  It is good for 90% shade.  Not only should it keep the driver side cooler/less hot, but, maybe the AC will run better.  If we need more clearance for the AC, I have a tent pole/PVC apparatus that will elevate the shade cloth away from the AC.  We’ll see how it works.  We pick up the Tab Friday in preparation for some work at nuCamp and then on to uCamp.
    "Hypotenuse" ... and no one ever thought that math was going to be necessary for fun things in life!!! ;)
    @Ratkity, I could not figure out how big a shade we needed, so this worked!  They even have an online calculator now,
    @SAM I rem when the first calculators came out! $300. Of course, @ericnliz remembers when the abacus was invented. :rofl:
    Ok, how about the slide rule.  Now you’re talking!
    @SAM my dad gave me one he used in engineering school (he worked for IBM for 34 years almost 20 years ago). I used it to make straight lines. hehe.
    My Dad used a slide rule until shortly before he was stricken with Alzheimers.  My brother looked for and found Daddy’s slide rule, a prized possession because my brother still remembers how to use it, too!
    It's also good to have friends when you run out of fingers & toes! :rofl:
  • 2Cougs2Cougs Member Posts: 922
    Hey folks... I'm not THAT old and I had to learn to use a slide rule in high school!!!
