Many of the places we like to camp up here in Maine do not have electrical and we want to add solar to our new T@B 400. I have been searching the forum but find most of the details on how others have done it apply to other models. The new T@B 400 is very buttoned up, I find it hard to get at the wiring.
I've looked at the battery disconnect switch on the right side. That might be a place to break into the wires with a terminal block, maybe. Maybe?
Inside the battery box? Have to figure out how to get the cover off, seems to be lots of screws that might be hard to access.
On the CB/Fuse panel? How do you get to the back of it? I see two (or three screws) on the back. Could I attach there?
Then were to mount the controller, and then put a port on the side of the trailer? Has anyone done that? I hesitate to start drilling holes into I know not what.
Odd thought: What about using the TV connector? It is supposed to provide battery charging. (Mine provides some charging at idle, but not significant. But a good long drive at highway speed does? Others observe that? )
T@B 400 2018 Tacoma TRD SR5
0 ·
@pthomas745, the battery/batteries for the 400 are under the bed inside, without a connection outside, unless you order a Zamp-type connection with it. Since the tow vehicle charges the 400’s battery, you can access the the 400’s battery lead through the 7-pin connector.
I have seen one 400 that the owner ordered a Zamp plug that is next to the cargo door on the passenger side of the 400.
To all in wildfire areas, stay safe!!! You are important.
Here’s how I hooked up my Renogy suitcase directly to the battery with ring terminals and a 10 gauge SAE plug.
Huntington LI
Huntington LI
Huntington LI
Huntington LI
I know this was a special order T@B 400, with special attention to proper placement of the necessary Zamp plugs.
Huntington LI
You can buy the Zamp port from Elsie in Parts at nüCamp, or you can them on Amazon. Be sure to measure 5 times, and drill once
@rcuomo the factory could show us all tricks for water sealing. Fact: the female Amish and Mennonite workers are better than the men at caulking and quality control. Pure fact.
(I hope this is not too huge, my apologies. ) Note the vent hose goes forward a bit. So a hole drilled directly below the vent might be in the wall there.
