On my most recent trip with the T@b, I discovered the trailer battery was not being charged by the tow vehicle.
I bought a mutimeter. When I check the truck side of things, there is power to the 12V battery pin.
If if I touch the probes of the multimeter to the trailer plug pin connections, I get nothing.
The trailer is a 2016 CS-S, with no Jensen. There is no battery disconnect switch in the trailer.
Im not great at dealing with electrical issues.
Help?
0 ·
Alan & Patty
Southern Az
If if there was a problem in the main positive line off the battery though, that would mean nothing would work off the battery, right? The battery is running all the 12V circuits in the trailer without issue.
Alan & Patty
Southern Az
The fuse at the battery is intact and not blown?
Connections at the battery are clean, not corroded, lugs are tightened down good, wire connections are crimped tightly, not loose, etc?
Positive & ground wire connections at the battery are intact and making good electrical connections?
I'm not sure when the factory started installing the on/off battery disconnect switches in the trailers but if there is one it should be in the tub area I'm guessing.
Alan & Patty
Southern Az
I opened the the junction box. Saw nothing weird, except that a white wire was pinched by the screw on cover. The casing was squished, but not cut. The positive and ground posts had power. Both the ground and 12V wire tested good for continuity.
So, if the truck end was good, and the trailer end was good, the only thing left was the connection between the two.
I took a small nail file to all the pins to clean them up.
I plugged in the running truck, and low and behold, I saw a voltage rise on the trailer.
I went and re-checked the 12V and ground line on the trailer plug, and got a reading, unlike the last time that checked. That part I found a little odd, but again, maybe it was just dirty pins that messed up the test.
So, for now it seems to be working again.
I’ll continue to monitor the situation.
Adventures: 58 Nights: 405 Towing Miles 50,180
