Just got back from a week in the Banff area. Due to some problems with our usual TV , the Xterra, had to take our trip with our 2014 Subaru Outback 3.6R with a 5 speed auto (pre CTV).
We already had a class 3 hitch, but at last minute got the 7 pin wired in and off we went. Luckily I got this device the day before we left. If not I'm pretty sure I would have done some long term damage to the Subie. Without it, I would have continued along in overdrive, driving the temps above what's healthy, but shy of the warning light. (Not sure when it comes on, but probably way too late.
With this device, and a free app on Android, I was able to monitor transmission temperature.
BAFX Products Bluetooth Diagnostic OBDII Reader/Scanner for Android Devices
https://www.amazon.com/dp/B005NLQAHS/ref=cm_sw_r_cp_apa_n4rvBbTHHC9KXWhat I learned is that you cannot use 5th gear at all, temps climb past 200 F immediately. In 4th I could keep temps between 200 and 220, but long climbs got up to 235 and once 263. Temps were cooler at 65mph than 60mph. Fuel economy was dismal at about 11-12mpg.
I will probably replace the transmission fluid soon. After this, we will only use the Subaru for towing if absolutely necessary, or very short trips.
I do know there have been others who had numerous issues so not sure where the true problems lie when pulling a T@B with a Subaru.
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
2022 Ford F350 Tremor | 2022 Cirrus 620
That being said, in the great Subie debate, engine cooling has always been the biggest concern. Also, I would never have towed with any of my previous 4 cylinder versions. We will probably upgrade TVs when Jan retires and we travel even more.
2009 Subaru Outback R 3.0
2022 Ford Ranger XLT Super Cab
aka BirdieJane towed by Quinn
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
Huntington LI
https://m.youtube.com/watch?v=glZGfBh4zTs
On my Volvo I would see temps around 105C(221F) on those really hot days towing. I installed this cooler and stays at 80C (176) or lower now, even on 90+ degree F days! I am very impressed with it. Now 220F for transmission temp is not bad and certainly won't cause an issue with your transmission if you maintain it properly. Anything above 240 degrees F is not good as it will start to deteriorate the fluid quickly and you can start to burn your clutches. I flush my fluid every 30,000 miles to play it safe. Fluid is very inexpensive, mine always stays a nice red color with no burning smell or issues. Even though I have the cooler I will continue to flush every 30k as well. It is cheap insurance. Here is a handy chart showing the fluid change intervals based on transmission temps. This may not apply to every vehicle but it is close enough for most cars.
