For those towing with cars especially Subaru
db_cooperdb_cooper Member Posts: 742
Just got back from a week in the Banff area. Due to some problems with our usual TV , the Xterra, had to take our trip with our 2014 Subaru Outback 3.6R with a 5 speed auto (pre CTV).
We already had a class 3 hitch, but at last minute got the 7 pin wired in and off we went.  Luckily I got this device the day before we left.  If not I'm pretty sure I would have done some long term damage to the Subie. Without it, I would have continued along in overdrive, driving the temps above what's healthy, but shy of the warning light. (Not sure when it comes on, but probably way too late.
With this device, and a free app on Android, I was able to monitor transmission temperature.
BAFX Products Bluetooth Diagnostic OBDII Reader/Scanner for Android Devices https://www.amazon.com/dp/B005NLQAHS/ref=cm_sw_r_cp_apa_n4rvBbTHHC9KX
What I learned is that you cannot use 5th gear at all, temps climb past 200 F immediately.  In 4th I could keep temps between 200 and 220, but long climbs got up to 235 and once 263. Temps were cooler at 65mph than 60mph.  Fuel economy was dismal at about 11-12mpg.
 I will probably replace the transmission fluid soon.  After this, we will only use the Subaru for towing if absolutely necessary, or very short trips.
  • larrygonlarrygon Member Posts: 255
    Been pulling our T@B with our 2014 Outback 3.6L CVT without issues. The Outback has 40,000 miles without issues. Pull up and down AZ mountains regularly. Been up and down the California coast a few times. Last time in for service everything checked out fine. Had all fluids replaced and new tires installed.
    I do know there have been others who had numerous issues so not sure where the true problems lie when pulling a T@B with a Subaru.
    "Great spirits have always encountered violent opposition from mediocre minds." Albert Einstein
    2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
  • db_cooperdb_cooper Member Posts: 742
    Based on what I saw with the temp guage, I'd recommend getting a transmission cooler if you don't already have one,  if you plan on keeping the car a while.  We like to get 200k and about 15 years out of our cars.
  • FerdFerd Member Posts: 16
    Last August we pulled our 320 from Sacramento to Portland with our Outback 3.6 and experienced the same temperatures (up to 260). The Outback was a great towing vehicle but after that trip we decided to trade it in for an Acura MDX. Unfortunately, Subaru doesn't make a transmission cooler for the Outback.
    But Subaru is coming out with the new Ascent this month. Top three models tow 5000#, has a transmission cooler plus more. We test drove it and it was very nice! 4cyl boxer turbo engine I think.
    Sounds like the new Subbie will be a game changer.  We are in the market to replace our Camry....hmmmmm.
  • JanandDaveJanandDave Member Posts: 119
    @db_cooper We have been pulling the T@B for a year with my 2009 R3.0 with no issues. It has a ‘real’ 5 speed transmission, too, with a factory built in cooler. In very hilly areas, I do shift into manual and use fourth gear (or third if needed).  Try to maintain the tongue weight at around 200-210 pounds. Installed foam coil spring inserts which help keep her level when loaded. Out of caution, I have changed the tranny fluid after each of our long trips, but have never found the fluid to be burnt or compromised. Average 15 mpg unless there are headwinds.
    That being said, in the great Subie debate, engine cooling has always been the biggest concern. Also, I would never have towed with any of my previous 4 cylinder versions. We will probably upgrade TVs when Jan retires and we travel even more.
    2016 T@B 320 Max S  "T@BsentMinded"
    2009 Subaru Outback R 3.0
    2022 Ford Ranger XLT Super Cab
  • trainwreckedtrainwrecked Member Posts: 31
    edited July 2018
    A transmission cooler comes standard on 2015 and newer Outbacks.
    2016 T@b M@x S Sofitel >- 2017 Subaru Outback 3.6
    edited July 2018
    No complaints or issues towing the T@B with our Outback over the past year and half, but the Ascent is nice!  They even have one towing a T@B in one of their commercials.  I saw my first one on the highway a couple days ago towing a pop-up, not nearly as giant as I thought it would be - just looks like an Outback that got a little taller.
  • BirdieJaneBirdieJane Member Posts: 237
    We are upgrading our 2016 2.5 Outback to the 2019 Acsent. The Outback has been a good car, just need more load capacity, we want to bring our canoe, or bikes. Toungue weight max for the car is just to light. Also the Acsent has a tow stabilization feature I think is a great addition.
    aka BirdieJane towed by Quinn
    With the right racking setup, you could bring both!
  • Travelin3DTravelin3D Member Posts: 174
    We are also planning to upgrade to an Ascent from our current Forester. We love the Forester but it just doesn't have the towing capacity we need for a T@B. Being brand new, the Ascent will be in short supply and have little discounting.
    Richie, Mickie and Satchmo
    2020 320S Boondock Lite (silver w/blue)
    2019 Subaru Ascent Premium
    Our Ascent is in order, looks like late August. We have the racks for bikes and our canoe, just not the load capacity with the limitations of the Outback.
    The Ascent looks great.  I'd still recommend the app and Wifi dongle above for monitoring stuff.  It also reads the diagnostic codes, much cheaper than buying a tuner.  Anyone towing with a car should have this IMO.  Unfortunately, I can't get it to read transmission temps in the Xterra, so I'll have to assume the transmission cooler is doing its job.
    Update our new T.V. Is in
    That is one nice looking TV! Is it the angle, my eyes, or is it not quite level.
    Nice! Looking forward to your review.
    @jgram2, it’s not hitched!
    Yes not hitched, just backed up when the photo was taken.
    Question: do it come ready-to-tow with a 7-pin connector and 12V charge line, or is that something additional? I know previous Subarus were only wired for a 4-pin connector.
    Hehe I had to look 2x before realizing it wasn't hitched. Nice looking TV!! Hope you get lots of great memories camping with that setup.
    As I surmised, it was my eyes.😳
    So when you order the car with a hitch it is installed at the port. The hitches where back ordered, ours will no be in until Monday. Dealer did not know if it came with a 7 pin connector. They tell us they will install one if it comes without.
  • rcuomorcuomo Member Posts: 321
    edited July 2018
    The accessories brochure shows a 7 pin connector with the factory installed hitch. And the Owner's Manual mentions that it has both a 7-pin and 4-pin connector mounted.
    Huntington LI
    @BirdieJane I’m so excited for you!  Our ascent should be coming in later this month, hopefully earlier! It’s my understanding that the touring model has a brake controller built into it, but I don’t know that the premium or the limited models do. We’re having a hitch installed and brake controller on a limited model. The top three ascent models have transmission coolers and some other braking sensor, I can’t remember what, built into them To handle the 5000 pound towing capacity anywhere. Enjoy!
    The parts dept told me it is wired for a 7 pin plug and the hitch install includes the plug. Apache Trailer recommended the Prodogy RF controller, It will arrive tomorrow
    edited July 2018
    Ok here is a video of the Ascent towing the Trailer of Doom utilizing the trailer stabilization system.
    https://m.youtube.com/watch?v=glZGfBh4zTs
    Wow! Never have seen the "Trailer of Doom" but can see why it is! Too cool
  • astory52astory52 Member Posts: 2
    I will be trailering my T@B  320 S with a 2018 RaV 4 Adventure package which has a towing capacity for 2900 pounds so I am hopeful all will go well.
  • dhaufdhauf Member Posts: 199
    I installed a transmission cooler from Amazon https://www.amazon.com/gp/product/B000C3F3SO/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
    On my Volvo I would see temps around 105C(221F) on those really hot days towing.  I installed this cooler and stays at 80C (176) or lower now, even on 90+ degree F days!  I am very impressed with it.  Now 220F for transmission temp is not bad and certainly won't cause an issue with your transmission if you maintain it properly.  Anything above 240 degrees F is not good as it will start to deteriorate the fluid quickly and you can start to burn your clutches.  I flush my fluid every 30,000 miles to play it safe.  Fluid is very inexpensive, mine always stays a nice red color with no burning smell or issues.  Even though I have the cooler I will continue to flush every 30k as well.  It is cheap insurance.  Here is a handy chart showing the fluid change intervals based on transmission temps.  This may not apply to every vehicle but it is close enough for most cars.
