I've been quite spoiled for a while and have had the luxury of being connected to city water for the last few weeks. I've just moved out to a new site and did my standard connection - camp water outlet to my white drinking water hose to my water filter to my brass pressure regulator to the T@B.
When I got back to my T@B after the first day, I noticed my fresh water tank was giving me a reading on the SeeLevel gauge. Weird, I thought, but maybe because I had recently sanitised it with bleach and perhaps I wasn't level before. So I drained it, and it read 0.
The next day it read over 30%. What the heck, I thought! But I didn't have time to deal with it. Then it read over 70% and now? Nearly 100%.
I found one article back in 2017 about something similar happening, but that person wasn't using a pressure regulator, something I always have done.
Anyone have any ideas on why this is happening and what I might be able to do to fix it myself?
Thanking you for any advice from a state of a bit of a panic!
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
Meanwhile, I was checking out that filter. I think the entire thing comes out (not just the clear section that looks like it might twist off to clean). Has anyone done this? Here are two pages that seem to show it's one unit (possibly only replaceable, not cleanable?). My T@B is a 2018 (purchased 7/2017) and it's the Shurflow 4008 water pump.
http://shurflo.com/rv-products/rv-accessories/rv-water-system-accessories/rv-strainers/112-twist-on-water-strainer-1-2-pipe-inlet
https://www.amazon.com/SHURFLO-255-313-Twist-Pipe-Strainer/dp/B000V2W0GE
"Turn off city water, open a tap, run the pump a few seconds, shut off, repeat a couple times. leave pump off, turn city water back on. Use a pressure regulator if you are not.
https://www.youtube.com/watch?v=6wsPiA09mXQManage
Sold 2023 Tab 400
Sold 2018 T@B 320S
But, I think, dsfdogs has the answer to your tank fill problem. Easy repair if you can’t reset the check valve. Good post- I learned something. Appears the Shurflow pump check valve does not always stand up to the rigors of continuous high pressure water.
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
I wonder if some people who had pump priming problems really had a wonky check valve (keep in mind there was a SMALL bad batch of pumps between 2014-2015 - I would say all have been replaced... they went bad fast! Sister had one).
Sorry for the rambling. I'm slightly decaffeinated!
I think the pump must have a one way check valve to prevent inflow from higher pressure city water (which sometimes fails, but can be reset) and the check valve at the city water connection prevents pumped water from coming out the city port. So, @TerryV6, if you have city water pressure down-regulated to 50, the pump would be working against that pressure. I agree with Ratkity, the pump would work harder. But, if your supplied city water pressure is so low that you actually have better pressure with the pump, it seems like that would not add additional pump stress. Terry, you were not alone - others did the same thing.
Anybody know the pump delivery pressure?
(Comment: I was much impressed with the man and his company)
T@bbey Road
Appleton, WI
This was actually an advantage because I could still leave the city water hose connected, but I could chose to use my fresh water pump during times of more consumption.
I do flush the tank (and also run the pump, flush the potty and turn on the faucet and shower) between trips because I'm a weekender and also do a good flush before a trip fill-up. I camp in places that don't have water hookups. Keep in mind that I make coffee with water carried from the house and drink cold water I also bring from the house. I guess I brush my teeth in the tank water. It's not that I'm paranoid of drinking the water because it's in the tank. It's just that the house water is heavily chlorinated (for me) and I drink water I refill in carboys. I also use that water because I don't get scaling in the coffee maker from minerals.
That said, I filter the water coming from the house I put in the tank and if I have water hookups at the campsite. It's a seasonal filter. I just leave the filter on the hose. I think it can also reduce scaling in the hot water heater (although the anode says otherwise - I have a traditional hot water heater).
comment made during the factory tour. Someone asked Joe about water left in the tank, and he said current designs did not completely drain. Joe’s words, not mine.
(We have tried at home to fill and drain the tank to get an accurate measurement. Me, I didn’t care, but I was ordered to help. My wife, having spent close to 30 years in different hospital labs, had to measure input accurately, and then drain and measure. Using the bal leveler and tongue jack, I tried to get it all out. Never quite did...)
Signed,
TerryV6 (no algae in my tank)
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
First, this page of shurflo pump specs has individual component part numbers..
It also shows the pressure levels for shut-off, restart, & bypass.
Also found this replacement part listing on amazon..
SHURFLO 94-800-03 Model 4008 Check Valve https://www.amazon.com/dp/B00XKZ31VC/ref=cm_sw_r_cp_apa_i_aaCxBb0906854
One of the reviewers stated this fixed the same problem he was having with fresh water tank filling from backflow of city water through the pump.
There may be other parts available that include more than just the valve.
