Better Alde plug
ChanW
Member Posts: 3,171
To prevent the 'bounce' from loosening our Alde plug, to make it lower profile, and to remove the extra wire from the compartment, I replaced the Alde plug with this one...
Chan - near Buffalo NY
2014 S Maxx (ie: "320")2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah!
5
simple, clean, effective!TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1 -
A better option would be a 120VAC, 20 amp locking receptacle and plug, same size, just rotates and locks in place.
Well, I was trying to avoid my usual overkill on this!. A hospital grade receptacle would hold the plug tighter too...
But this has worked great for 7 or 8 years - absolutely, has stayed just as you see it!...
A_Little_T@b'll_Do_Ya1 -
True, a hospital receptacle would also work.
Yes, the 320 Alde plugs have that history of shaking loose. Good idea @ChanW.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
You mean things have a tendency to shake when towed????
I like the right angle plug, and if that one gets loose you could sling a zip tie around it and the receptacle box. I'll be doing the same thing when I put mine back together. DaveR middleTN - 2015 320S / TV 2003 Tundra 4x40
