I've seen it mentioned here before that you should open your hot and cold drains (and open a faucet) to your Alde unit after every camping trip. Seeing as they're under the bed panel in the 400, is this a realistic expectation or was I misinformed? I can do it...but do I HAVE to do it?
2021 400 BD
2020 Tacoma TRD Off-Road
0 ·
There are two drains in the bottom of the Nautilus panel (which appear to be color coded hot and cold), one freshwater drain underneath (the fresh tank low point?), and apparently another under the bed (referenced in this thread) that I haven't seen yet. Which or how many of these do I need to drain, and in what order?
I've been searching the threads but all the models and years are different, so I'm trying to find some 2021 T@B 400 Boondock specific guidance here.
Any help appreciated.
Cheers,
C
2018 Jeep Grand Cherokee Trailhawk V6
veni, vidi, bibi capulus
SW Montana USA
Now I'm on a quest to figure out which to engage when and for what reasons and in what order...
Who would have thought that black and gray sewage would be simple and fresh water would be complicated...
Assuming later models are plumbed in the same manner--and it sounds like they probably are--there should be no need to open the yellow flap valves for routine system draining.
I actually have about 12" of heavy memory foam mattresses so lifting those along with the sheets blanket etc isn't going to be an option for me. I will just have to move everything out at the end of the season and flip the valves when I winterize just to make sure nothing is left in there. That's the best I can do, but it sounds like it's fine not flipping them anyway!
The plumbing in newer T@Bs is considerable more complex, but you should be able to figure out the draining patterns by tracing the piping in the Alde compartment. I'd bet a nickel the Alde's CW supply line ultimately leads back to the main CW low-point drain.
