Moving Battery Inside
2»
    Denny16 Member Posts: 5,430
    edited March 2022
    Yes, yes it does.  Glad we both survived our towing incidents.   B)
  • MadCityJack
    MadCityJack Member Posts: 110
    @Denny16 and @VictoriaP
    Great stories.  Are they code for something?   :)
    2017 T@B 320 Q Max
    2018 Toyota Highlander, XLE
    Wisconsin
    No, just sharing past experiences…
  • Marceline
    Marceline Member Posts: 1,776
    I just couldn't tackle the project of moving my battery inside. Here's my solution.
    First, I was having a mouse problem where I store my trailer (see the shredded label on the battery), so the lithium battery needed to go into a sealed box, not a conventional battery box. I searched high and low for a box that would fit in the tub, and finally found a plastic file folder box that holds the Group 24 style LiON Energy battery plus the SmartShunt. The box is bolted to the bottom of the tub and I can lock the box with a vinyl coated cable. There is one minor oopsie in the wiring that I need to fix.
    Thanks for coming to my rescue @Denny16. I couldn't download the diagram that I had saved to the cloud in preparation. Lesson: always print out a hard copy of your plan.
    Glad I was able to help Marceline, your project came out very nice.
  • Horigan
    Horigan Member Posts: 915
    Ha!  That's the file folder I use for my files at home!
    Rich
    2019 T@b 400
    Bellingham WA
