This is an Alde question. When boondocking, we have two batteries that we switch out each morning with each other, in order to re-charge (with our Renogy solar panels) the battery that has been in use. The system seems to work well. HOWEVER, we have noticed that our Alde gets "cranky" and sometimes does not heat the water as it should AND/OR sounds like it is continually running and exhausting HOT air out by the burner AND/OR, is draining glycol. We wonder if the problem is that we something is somehow related to our switching over of batteries??? FYI, we had not had issues with the Alde system before we started the switching of batteries, although we had only used our 2021 Tab 320S several times.
0 ·
As for switching out the batteries, we just feel then that we will have no issues with power. And, charging with our Renegy portable panels is pretty easy to do.
Can you elaborate on these problems you are having?
