Can AGM batteries be charged through the 7 way plug for winter?
SgtYork
Member Posts: 34
I have a 2021 TAB 400 and the batteries are at 12.4 volts. Would like to top them off before it gets too cold. Can I run a AGM battery charger through the 12v lead in the 7 way plug? No power availble at the camper but I can run an long extension cord to the camper shed with a battery charger.
Is this doable? Thanks, Earl
Maybe I’m misunderstanding something, but if you’re running an extension cord to the camper shed anyway, why not just use an 15 amp adapter and your 30 amp cord to charge the trailer batteries? What advantage is there to using the 7 pin?2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
Even without the 15 amp adapter, why would you not want to connect a charger directly to the battery? We do what @VictoriaP suggests, and we use a 30 amp extension cord in addition to the regular 30A cord, plus the adapter at the household outdoor outlet.-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods -
Thanks for the reply. Cord is over 50ft long. And everytime I tried to connect the TAB 400, TAG, or Mini Lite campers to the outlet it blows a house fuse. But I can run battery charger with no problems.
YES I made this adapter for easy connection of any charger source to the trailer 7-pin pigtail.
Yes, yes you can use any 12 VDC charger designed for AGM battereis. Most new chargers have a switch to set them to AGM or Flooded (lead acid) batteries.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
Thanks guys!!
- 917 Introductions
- 73 Teardrop Groups & Links
