Can AGM batteries be charged through the 7 way plug for winter?
I have a 2021 TAB 400 and the batteries are at 12.4 volts. Would like to top them off before it gets too cold. Can I run a AGM battery charger through the 12v lead in the 7 way plug? No power availble at the camper but I can run an long extension cord to the camper shed with a battery charger.
Is this doable? Thanks, Earl
  • VictoriaP
    VictoriaP Posts: 1,496
    Maybe I’m misunderstanding something, but if you’re running an extension cord to the camper shed anyway, why not just use an 15 amp adapter and your 30 amp cord to charge the trailer batteries? What advantage is there to using the 7 pin?
  • BrianZ
    BrianZ Posts: 1,770
    edited November 2021
    Even without the 15 amp adapter, why would you not want to connect a charger directly to the battery?  We do what @VictoriaP suggests, and we use a 30 amp extension cord in addition to the regular 30A cord, plus the adapter at the household outdoor outlet.
  • Thanks for the reply. Cord is over 50ft long. And everytime I tried to connect the TAB 400, TAG, or Mini Lite campers to the outlet it blows a house fuse. But I can run battery charger with no problems.
  • rfuss928
    rfuss928 Posts: 1,192
    YES  I made this adapter for easy connection of any charger source to the trailer 7-pin pigtail.
  • SgtYork
    SgtYork Posts: 34
    Thanks rfuss928. Do you have the pin outs that I need to connect too?
  • rfuss928
  • Thank you rfuss928!!!
    rfuss928  What battery charger and and voltager do you use. I have 2 6volt agm inline batteries. So can I put a 12volt agm charger to the 7 way? Thanks, Earl
  • Denny16
    Denny16 Posts: 5,430
    Yes, yes you can use any 12 VDC charger designed for AGM battereis.  Most new chargers have a switch to set them to AGM or Flooded (lead acid) batteries.
  • rfuss928
    Yup, what Denny16 said.  I also use it for my remote solar panel input when needed.
  • Thanks guys!!
