Small Cabinets above Sink and Stove--How to modify so the will stay up and open while in the trailer
2smellthepines
Member Posts: 2
2016 T@B model S. Has anyone figured out how to fasten the "lift up small cupboard doors" to the ceiling, so that we don't have to hold them up and open in order to remove or add items
I searched Cabinet Door Struts:https://tab-rv.vanillacommunity.com/search?adv=&search=Cabinet+door+struts&title=&author=&cat=all&subcats=1&tags=&discussion_discussion=1&comment_comment=1&discussion_poll=1&within=1+day&date=
@2smellthepines there have been changes to the cabinets over the last several years. On my 2017, the cabinets raise to just above level and stay. I have to push them down and latch in place. The years before, owners did mods to hold cabinet doors up or open. One method uses springs and another uses small hydraulic piston arms. You can use the search feature in the upper right hand and type a few key words to find whole threads on these topics with pictures and instructions. If you need assistance, post again and I'll dig into my archives as I know I saved some of those photos somewhere. -Denise2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
A simple part for part replacement is the simplest and most effective fix. Holds the doors up with nothing else added.
https://www.amazon.com/Amerock-BP2811J23-14-Adjustable-Concealed-Hardware/dp/B00NX1UXIC/ref=sr_1_2?crid=HICT9CVDEZC&keywords=amerock+bp2811j2314&qid=1658958260&sprefix=Amerock+BP2811J23,aps,1824&sr=8-2
I used one of these hinges on each door (leaving the original on the other side) and it is enough to hold the doors up.2smellthepines said:2016 T@B model S. Has anyone figured out how to fasten the "lift up small cupboard doors" to the ceiling, so that we don't have to hold them up and open in order to remove or add items
I have used these and had good results.
RV Designer H279, Door Support Strut, Plastic and Metal, Spring-Loaded 6-1/4 inch, 2 Per Pack, Cabinet Hardware
2020 TAB 320 U
TV 2025 Telluride X Type0 -
Interesting. The upper cabinet doors on my 2015 stay open on their own. However--as testified by the divots in my forehead, I wish they didn't... ;-)
rfuss928 - did you recently purchase these from Amazon? Several years ago, I bought these and they worked great. A friend recently bought these from Amazon and they do not have the "Stay Open" feature.2016 Outback 320
Tabaz
I've had mine for several years. I would be surprised if Amerock made changes without changing the part number. There are several models and manufacturers of very similar, interchangeable hinges. Many, including those originally installed, do not have strong enough springs to hold the doors up.
Mine originally came with an additional, different, hinge in the center to assist the hold open. The Amerock BP-2811J23-14 did not need the assist and held the doors further up against the ceiling than the originals.
thank you...it sounds like the answer0
I have a 2015 and they don't stay open. I'm looking at them to see if there is any sort of adjustment to make to the existing hinges to help them stay open, but I think probably not since they don't latch when down.ScottG said:Interesting. The upper cabinet doors on my 2015 stay open on their own. However--as testified by the divots in my forehead, I wish they didn't... ;-)
On the 2018 tab 320s the cabinet doors stay open about parallel to the floor which is great but also something else to hit your head on!0
Can you add a photo to show how you used these? I got them but I don't see how they will work (perhaps too long).Freespirit said:I have used these and had good results.RV Designer H279, Door Support Strut, Plastic and Metal, Spring-Loaded 6-1/4 inch, 2 Per Pack, Cabinet Hardware
