Water Pump Issue - Any ideas on accessing the PEX behind the toilet?
I have a 2019 T@B 320s Boondock Edge with water pump issues. The system runs fine on city water. I have disconnected the water pump intake hose and put it into a bucket and the pump is sucking water through the pump. This leads me to believe I have air entering the system somewhere on the intake side of the pump.
I had to replace the sink last summer and know that the PEX moved around a lot during this repair.
Thanks to earlier posters I have a photo of the wall behind the toilet.
Any ideas on how best to find the air leak short of cutting a hole in the wall?
Thanks!
2019 320s Boondock Edge
TV is 2007 Kia Sorento EX with 3.8L engine
    @crosstrnr, this was the very first question I asked when I joined the forum in 2015. Unfortunately, there were no good answers. A few years later when I spring a small leak in a PEX fitting down in those nether-regions, cutting a hole in the wall was exactly what I had to do.
    The project was less traumatic than I expected, and now I am happy to have a (sort of) easy way to get into that awkward space if needed.
  • crosstrnr
    crosstrnr Member Posts: 24
    edited January 2023
    @ScottG
    What did you use to reseal the hole when done? Concerned since we do use the shower.
  • Grumpy_G
    Grumpy_G Member Posts: 784
    Your test of the pump might be misleading unless the intake water level was below the floor like the fresh water tank. I was fighting a similar/same issue a year ago and the pump bench tested fine from a bucket. I ended up replacing the pump. PEX is pretty rugged so it's not very likely it sprung a leak.
    crosstrnr said:
    @ScottG
    I used vinyl foam weatherstripping on the back of the cover. It appears to do the job just fine.
    https://tab-rv.vanillacommunity.com/discussion/comment/116858/#Comment_116858
  • crosstrnr
    @ScottG
    I completely missed the link in your first post -- great explanation and photos. Looking forward to working on this once it warms up a bit.
