Can I remove my Air8 filter by myself for cleaning? TAB 320 S boondock
ClaireFM
Member Posts: 12
Hi, all: Below is a picture from Paul the Air Force Guy of what I think is the filter cover for the Air8 filter in my TAB 320 S. Can I remove this by myself? It looks a little intimidating, and there seem to be some screws at the bottom of the cover. I'd like to check the filter and perhaps clean it by myself. Thanks so much.
This might help:
'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,1801 -
Here is the discussion link. https://tab-rv.vanillacommunity.com/discussion/10682/filter-location-on-air8-on-t-b-400-s“Filter location on air8 on tab 400s”Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Thanks to both of you!1
@MuttonChops Do you recall how hard it was to lift out the hose assembly. On my 320css it is very tight and since it seems to be some type of styrofoam I'm reluctent to pry too much. Thanks.
Alan
2022 Tab 320cs-s
2020 Honda Ridgeline0 -
Sorry, I have no direct experience with the Air8 unit.
Hopefully, another forum member can assist you.
Adventures: 58 Nights: 405 Towing Miles 50,1800 -
Hi,
In my '21 with the Air 8, the air hose plenum is not removed. There is a snap on grill in the front. Then there is a mesh pre-filter and behind that is a filter that looks like a car cabin filter. I just cleaned mine after moderate use of 3 years. The mesh filter was rather dirty, but the pleated filter was mostly clean. I vaccumed both clean and reinstalled.2025 360 CS
Southern Maryland0
- 143 Events & News
- 922 Introductions
- 411 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
