locate source of stray current to earth
Background:
2020 Tab400 Boondock Lite
has stock 24v solar
haven't otherwise messed with electrical
converter circuit breaker off
inverter is off at remote switch
battery switch is off
parked on asphalt in storage-unit lot for months - daily trickle and vampire power seems reasonable
not connected
Observation:
Lying on my back the ground under trailer re-attaching the bottom insulation and I notice tingling sensation when I touch the frame and brake housing. (and tire)
DC voltage: frame to me measures zero.
AC voltage reads 30 and it's reduced when I'm lying on the yoga mat.
I don't currently have better ground than lying on the ground.
Question:
Any thoughts why could be an AC current to earth?
  • Dave_J
    Dave_J Member Posts: 5
    I just figured it out - it’s under high voltage transmission lines.
  • Grumpy_G
    Grumpy_G Member Posts: 784
    Interesting. Just the other day I saw something about putting a metal fence near high voltage transmission lines to scavenge power. Can't be anything purpose built but fences are ok.
    More typically AC to ground happens when hot and neutral are reversed at the power socket.
  • rfuss928
    rfuss928 Member Posts: 1,192
    edited January 2024
    If the observed "current to ground" disappears when you disconnect the trailer from the AC hook up, then it is the reversed ground problem Grumpy_G describes.  Otherwise, I suppose it could be the power lines effect...?
