Yet Another Exterior Lagun Discussion
2»
  • Verna
    Verna Member Posts: 6,876
    In a pinch, Clingwrap on the outside of the vent will work while camping. It won't stay on during travel. First hand experience.....
  • dmerzbac
    dmerzbac Member Posts: 289
    @hymie Have you been pleased with your 7350 and vent cover? I'm trying to make a decision between the 7350 and the maxxfan 7500.
    2017 T@b 320 - 'Smokey'  2017 Toyota Tacoma TRD Sport - 'B@ndit'
    Dave - Tuscaloosa, Al
  • hymie
    hymie Member Posts: 150
    @Homebodyatheart 2.0 will likely be a variant of one I saw on the fb group. The built an aluminum frame that had a checkerplate cover that hinged up and stays similar to the t@b windows. Very slick and looked great. I'll see if I can find a pic....
    James & Jacquie     Almonte, Ontario
    2016 Jeep Cherokee & 2017 T@B Outback
  • hymie
    @dmerzbac Love this mod! What is really appealing is that you do not need to disturb the housing and seals. Less than hour to do both fan and cover. Ordered the upgrade kit direct from FF and got it at half (!!!!!!!) the price that I was quoted at several dealerships.  Quiet and very low power consumption. Rain sensor and auto open / close are almost pointless with cover though. I would do this again in a heartbeat.
  • dmerzbac
    @hymie Was the vent cover a fairly easy install also? I would guess screws were needed to attach.
  • hymie
    edited May 2017
    @dmerzbac 8 self tapping screws (stainless steel - included) .. Cover took 15 minutes.
  • hymie
    @Homebodyatheart Credit and kudos to Joseph Langrek on fb t@b group.
  • Ratkity
    Ratkity Member Posts: 3,770
    @hymie, did you install a plain 2 wire rocker switch for the Jensen, or an LED lit rocker switch (has 3 connectors)?
  • hymie
    @Ratkity I put in a three connector rocker (leftovers from another project)  but only used two. Didn't want the parasitic drain of a lit switch.
  • dmerzbac
    @hymie Take lots of photos as you work and when you finish the job. =)  That looks incredible!
  • dsatwork
    dsatwork Member Posts: 744
    @hymie Nice work
  • hymie
    edited May 2017
    @dsatwork. Not my work. This a fellow on Facebook that has a great idea. Thanks though....
    I think the factory should consider this.
