Yet Another Exterior Lagun Discussion
In a pinch, Clingwrap on the outside of the vent will work while camping. It won't stay on during travel. First hand experience.....Verna, Columbus, IN
@hymie Have you been pleased with your 7350 and vent cover? I'm trying to make a decision between the 7350 and the maxxfan 7500.
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
@Homebodyatheart 2.0 will likely be a variant of one I saw on the fb group. The built an aluminum frame that had a checkerplate cover that hinged up and stays similar to the t@b windows. Very slick and looked great. I'll see if I can find a pic....James & Jacquie Almonte, Ontario
2016 Jeep Cherokee & 2017 T@B Outback -
@dmerzbac Love this mod! What is really appealing is that you do not need to disturb the housing and seals. Less than hour to do both fan and cover. Ordered the upgrade kit direct from FF and got it at half (!!!!!!!) the price that I was quoted at several dealerships. Quiet and very low power consumption. Rain sensor and auto open / close are almost pointless with cover though. I would do this again in a heartbeat.James & Jacquie Almonte, Ontario
@hymie Was the vent cover a fairly easy install also? I would guess screws were needed to attach.
@dmerzbac 8 self tapping screws (stainless steel - included) .. Cover took 15 minutes.James & Jacquie Almonte, Ontario
@hymie, did you install a plain 2 wire rocker switch for the Jensen, or an LED lit rocker switch (has 3 connectors)?2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)
@Ratkity I put in a three connector rocker (leftovers from another project) but only used two. Didn't want the parasitic drain of a lit switch.James & Jacquie Almonte, Ontario
@hymie Take lots of photos as you work and when you finish the job.
That looks incredible!
@hymie Nice work2017 Tab Basic S Silver on Silver with Sofitel Cushions....upgraded from 2013 LG 5W....Towed by a 2016 Sorento V6 AWD w/5000lb tow capacity. Dave S. married to Jen aka SanDiegoGal We pull a Tab but live in a 2014 Airstream International Signature 27 FBQ...Talk about embracing a trailer lifestyle.
@dsatwork. Not my work. This a fellow on Facebook that has a great idea. Thanks though....James & Jacquie Almonte, Ontario
I think the factory should consider this.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
