Fantastic fan noisey
4ncar
4ncar Member Posts: 1,072
Is it my fan, or is everybody’s fan noisey? I mean like wines like crazy to the pint I don’t want to run it at night...
2018 320S Outback
  • jkjenn
    jkjenn Member Posts: 6,417
    I upgraded to the 10 speed Fantastic Fan which not only uses less power, but can be reduced to a quieter speed.
  • Tabaz
    Tabaz Member Posts: 2,421
    I don't run mine for the same reason. Even on the low setting, the noise is too much. Do some research before spending money on the variable speed model. Someone posted here that the lowest speed on the variable model is the same as the 3 speed model (I.e. Same rpms = same noise level). Jenn's post seems to contradict that assumption.
    2016 Outback 320
  • jkjenn
    I doubt that this is true. When you put it all of the way down to the lowest speed it is super slow and almost silent. It's been 2 years since I made the switch, but I could not work with it even on low and take a conference call with the standard fan but could with the 10 speed fan.
  • db_cooper
    db_cooper Member Posts: 749
    The amp draw on the 10 speed gets really low,  this mod is on my radar since we tend to boondock.
  • Luckyj
    Luckyj Member Posts: 286
    I have found on a different forum that the control could be change, and this is what I am doing right now.  I found a complete 12 volts no set speed variable switch, that make it very slow, so slow that I have foumd a squil noise form the bearing or bushing.  So it goes from almost stop to regular full speed, and I will use the directional switch to turn it off.  Al in all, about 10,00$.
    but I do not remember the name of the switch.  It is mounted with a pcb board.
    TV 2005 jeep TJ unlimited
    Alaskan Malamuthe on board!
    Les Escoumins and Petite-Riviere-St-Francois QC
  • Tabaz
    I recall someone mentioning the low variable was the same speed as the low 3 speed switch, so I didn't pursue the mod at that time.  Luckyj - please post more info on that variable speed switch once your done with the mod.  That would sure save us a lot of money and time.
    2016 Outback 320
  • JandJ92010
    JandJ92010 Member Posts: 304
     I wired in a separate on/off switch and wired in a 12 volt cooling fan from a computer, hung it with small bungee cords under the regular fan. A nice little bit of white noise and ventilation. We can use either fan, which ever one is desired.
  • gbell
    gbell Member Posts: 88
    Jandj please post the how to do on here, I like the idea of the small fan without disturbing the other fan.
  • Verna
    Verna Member Posts: 6,876
    The tnttt (teardrops n tiny travel trailers) for has the instructions for putting a rheostat in-line on the Fantastic Fan. No, sorry I haven’t visited there for some time so I don’t have a link.  There might be a link on the old Little Guy Forum.
  • Tabaz
    Here is the link to TNTTT (nine pages of VERY technical discussion):
    http://tnttt.com/viewtopic.php?f=30&t=25351&sid=0905372812de5916c28020fd405dcaae&start=60
    Way over my comprehension.
    2016 Outback 320
  • JohnDanielsCPA
    JohnDanielsCPA Member Posts: 238
    I had a ten speed installed at the factory as an option.  At the lowest setting, you hardly know it’s running.  I bought it, mainly, because the lower speeds will still move air but use less amps than the three speed.  For long-term boondocking, I try to find every miliamp I can find.
    2022 T@B 400 BD
    2019 Ford F-150 3.5L Ecoboost with Long Bed
  • 4ncar
    @JohnDanielsCPA was the 10 speed special order? I see nothing on their web site...
    2018 320S Outback
  • Rolltide82
    Rolltide82 Member Posts: 89
    edited March 2018
    Mine is loud.... however I can sleep through a hurricane.....
  • 4ncar
    edited March 2018
    Mine is loud... however I can sleep through a hurricane.....
    Lol! I even used brush cleaner & Teflon lube...no change!
    2018 320S Outback
  • jkjenn
    It is remarkable what a difference even the lower speeds can make by just keeping the air moving.
  • Ratkity
    Ratkity Member Posts: 3,770
    I think I did sleep through one in 2004.... :lol:
  • JohnDanielsCPA
    @4ncar, yes, I specifically asked for the 10 speed fan, as I have one on my fifth wheel.  It was not listed as an option.
    2022 T@B 400 BD
  • SweetlyHome
    SweetlyHome Member Posts: 336
    We sleep with it on regularly.  Of course we have slept through hurricanes: Wilma, Irma etc.
    Jupiter, Florida~T@B 400, with 2018 Toyota 4Runner
  • LSkrabut
    LSkrabut Member Posts: 136
    I was able to custom order to be install at the factory the FF 7350 version. Nice to know it has lot less power drain and low speed is very quiet. The fridge fan is the noisy item in the 400. I have yet to need the AC, I fully suspect that would be the loudest fan noise in the entire unit.
    Utah Driven
    2019 T@B 400 (Ex 2018 400)
    2015 MB GLK 250 Diesel
    2018 GMC Canyon Denali Duramax CCSB
  • Silver320
    Silver320 Member Posts: 29
    I thought the FF was noisy too so had it replaced with the MaxxAir 7500K today.  Very happy with the MaxxAir as it has 10 speeds and is very quite on the lower settings.
    2017 T@B Max S (Silver-Silver), TV 2017 Jeep Grand Cherokee Trailhawk
  • 4ncar
    What I don’t understand is why FF does not disclose on their site that the “fancy” units are or are not 10 speed.  Are the special order only?
    2018 320S Outback
  • LSkrabut
    FF direct site does show for the 7350 model there are 13 speeds, while all other versions are 3 speeds.
    http://www.fantasticvent.com/fan-tastic-vent-s-retail-12-volt-fans.html
    OEM versions (5000 and 6000) are variable, but wall controlled only.
    I am wondering if the 10 speed units where an older version that was offered in the past?
    Utah Driven
