Alde 3010 Compact Heater
jmazelis
Member Posts: 2
I purchased a 2015 T@B Max S with an Alde 3010 compact heater. It will operate using propane, but not on electricity. I replaced the fuses in the unit. Does anyone have any other suggestions as to what the problem may be?
Welcome and congrats! I also have a 2015
Can you post a photo of how you have the sliders set and where you are plugging into for shore power (30amp?)2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Boy, this sounds familiar. Didn’t someone just have this exact problem?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
First make sure the unit is plugged in under the driver side bench.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Also make sure there is power to that outlet. Try plugging a light into it and see if it lights up. If not reset the breaker by turning it to the off position then to the on positionSAM said:First make sure the unit is plugged in under the driver side bench.- Hash T@B Fun
2
