Hi, I'm quite new to the forum.. I'm going to be taking delivery of my 320 S Boondock Edge this weekend.. and have been doing a bunch of research for the stuff I want/need
One of my own personal absolute must haves is a generator so I can run the AC when off grid during summer heat/humidity.
All relevant "polite neighbor" stuff taken as a given I am looking to get the quietest generator I can. I've been really struggling between a smaller 2kW model and a 3-3.5kW model. I know the AC in the 320 can run off a 2kW generator under most conditions, though I've read that at high altitudes sometimes they can't quite start the AC.. though I figure if I'm that high up, I'd be less likely to need it ... so maybe that's not a worry?
The other thing is that I've noticed that all the specs .. every time.. it seems like the camp quiet generators that are in the 2kW range are actually slightly more noisy than those in the 3-3.5kW range .. I assume this is due to lower RPM/Bigger cylinder and/or more sound mitigation?
I am 99% sure I want a dual fuel generator and would plan to run it exclusively off Propane.
Everything I read/watch on the subject says that propane
CON
* delivers slightly less power (generators take a 100 to 200 watt hit on starting/running output)
* slightly more bulky due to metal cylinders
* slightly more expensive to run
PRO
* is way safer to store/transport
* creates only half the CO of gasoline
* is way cleaner for the innards of the generator (doesn't build up deposits in carb the way gasoline does)
* has "Unlimited shelf life" (no gas going stale on you) and that generators run a bit more quietly under it.
* run time on one "fill" is longer on one tank of propane than on one tank of gas
I had looked through these forums on the topic and found quite an old one..
https://tab-rv.vanillacommunity.com/discussion/4082/generator-dual-fuel
It appears that there weren't so many camper friendly/quiet options back then?
Found this discussion of one of my two choices
https://tab-rv.vanillacommunity.com/discussion/6616/champion-inverter-genoratorI'm kind of down to should I get this one or that
Champion 3400-Watt Dual Fuel RV Ready Portable Inverter Generator with Electric Start
This is 3400 starting / 3100 running W on gasoline so it's got more power than I need
Do not know the values for propane but assume baout 3300 / 3000 or 3200/2900 based on typical values I've sen
weights about 100 lbs
rated about 59dB in sound
runs 14 hrs on 1 tank propane or 7 hours on one tank gas (25% load)
DuroMax XP2000EH Dual Fuel Inverter Generator
This is 2000w starting / 1600 running on gasoline
1900 w starting / 1500 running on propane
weighs about 53 Lbs
had to dig for db level as it wasn't listed on the amazon listing but chainsawjournal said 61dB
runs 21 hours on 1 propane tank, just under 7 on gas (smaller gas tank)
So I'm really struggling.. on teh one hand I think the smaller generator will work for me.. I KNOW The bigger will but the added cost and weight .. I just am not sure how to really decide..
If folks have thoughts/ suggestions / corrections I'd be really interested to hear them as I'm paralyzed with "which one!!!!"
I have seen Yamaha's converted to propane also, there are a few companies that could provide the kits for potentially a number of generators?
2019 T@B 400 Boondock
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
I'm New to nuCamp and TearDrops but have owned a Class A in the past
WilliamA
2017 T@G XL
Totally hear you (pun intended) about the two smaller ones in parallel will be way louder than a single bigger one even under full load.. that Champion is really quiet
Really it comes down to: do I want to risk having ~just enough~ capacity to power my A/C or charge batteries/ run computer stuff that I need for work....... but have something super easy to manage, maybe even semi perma-mount it to the hitch area with extended exhaust..
OR
Do I want to have a generator that totally will meet my power needs but will be right at my own personal limit for being able to get it in and out of the back of my Tow Vehicle (which is where it will have to live as no way would I be able to perma-mount it
The 2019 I would have no issue with using a 2k generator on it. The 2020, I am in wait and see mode.
edit for spelling
I've really been going back and forth and think my ultimate answer may be .. I'll get the smmaller unit and really make sure I run it through a good shakedown before I get too far into plans for bigger travels .. if it fails to meet my needs/expectations, I'll buy the bigger one and sell the 2k knowing that I NEED the bigger one. I'll take a hit over having bought the big one right up front, but will know absolutely that it was needed.
My current plans involve some extended trips.. I telecommute for work and can do my job anywhere I can get good Internet.. My power needs for worst case (I'm somewhere I need to work entirely off cell signal and generator are a Laptop, maybe an LCD monitor, keeping my phone topped off and running the A/C (assuming it's hot)) so long as the A/C on the TaB starting draw isn't horrendous, it should only draw about 575 watts running?
Thanks for all the thoughts/suggestions. I'll let folks know how it goes longer term
I also have a T@B 320 S, and other than the Alde running with both heating elements (~2000 watts) on 120 VAC (a loosing proposition from a generator IMHO), the next largest load is the AC unit and/or the converter. The AC unit only draws about 4-5 amps, so no problem there. The fridge uses about 2 amps AC, but again, a loosing proposition to run it from a generator when it will run on LP just fine. I replaced the WFCO converter with Progressive Dynamics Lithium 30 A model, which draws somewhere in the area of 9 amps at full output and almost nothing with a fully charged battery.
Bottom line here is that I can't think of any built-in T@B 320 appliances that would benefit from a generator any bigger than the Honda EU2200i that I ended up getting. The only reason I can see to get a higher power generator would be to run external appliances such as hair dryer, cook-top, toaster, etc. One of the things that I love about the T@B is the extreme energy efficiency and the ability to run it with my 200 watt roof top solar and the Honda EU2200i generator when needed. See the link in my signature for more info on my setup.
John
2007 T@B
Rockford, IL
A proper ground rod is what 5 or 6 feet long? Sinking it into the ground is easy enough with the use of an impact drill. That how I did mine at home and the work shop.
But how do you get it out of the ground to reuse it on the next trip.
Maybe this is what @Jilong is thinking of. The bonding of the neutral with a grounding plug.
This is not an actual ground rod, but a specially wired plug to bond the neutral wires.
I have the plug that RZRBZUG made, although I have not used the generator yet.
