Chirping inside my T@B
System
System Administrator Posts: 190
This discussion was created from comments split from: Surge Protector Used When Home?.
  • JMP
    JMP Member Posts: 1
    Hello, I am new to this forum. I have a question about a chirpping sound inside our Tab teardrop (2016 model CSS) and looking through the manual, I can't find any reference to what might be the issue. The unit is plugged into a dedicated 30 amp circuit, and it has been this way since last October.  I have tried the reset switch on the CO detector and it still continues to have this chirp sound. Does anyone have a clue as to what I need to do to fix this?
    Thanks,
    Jeanne in CA
  • Verna
    Verna Member Posts: 6,876
    @JMP, Jeanne, welcome to the T@B forum.
    Using the search function (upper right corner of the page), I found this discussion, along with many more on the forum:
    https://tab-rv.vanillacommunity.com/discussion/comment/104535#Comment_104535
    Not the smoke detector?  If you suspect it is the CO detector, perhaps a fuse needs to be checked?  Consider replacing the CO detector.
    pthomas745 Administrator, Moderator Posts: 4,648
    If it is the gas alarm, check your battery status.
  • rfuss928
    rfuss928 Member Posts: 1,192
    My LPG alarm will chirp when the battery is low.
    They are plugged in.  Does it change if you disconnect the battery?
    My first guess would be a low battery in the smoke detector. If not that, check the propane/CO detector--you should have an owner's manual for that device that will help you interpret its various vocalizations.
    Other than that, the only other plausible explanation is crickets...  ;-)
