Chirping inside my T@B
System
Administrator Posts: 188
This discussion was created from comments split from: Surge Protector Used When Home?.
Hello, I am new to this forum. I have a question about a chirpping sound inside our Tab teardrop (2016 model CSS) and looking through the manual, I can't find any reference to what might be the issue. The unit is plugged into a dedicated 30 amp circuit, and it has been this way since last October. I have tried the reset switch on the CO detector and it still continues to have this chirp sound. Does anyone have a clue as to what I need to do to fix this?
Thanks,
Jeanne in CA -
@JMP, Jeanne, welcome to the T@B forum.
Using the search function (upper right corner of the page), I found this discussion, along with many more on the forum:
https://tab-rv.vanillacommunity.com/discussion/comment/104535#Comment_104535
Not the smoke detector? If you suspect it is the CO detector, perhaps a fuse needs to be checked? Consider replacing the CO detector.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
If it is the gas alarm, check your battery status.
Towed by 2014 Touareg TDi -
My LPG alarm will chirp when the battery is low.
They are plugged in. Does it change if you disconnect the battery?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
My first guess would be a low battery in the smoke detector. If not that, check the propane/CO detector--you should have an owner's manual for that device that will help you interpret its various vocalizations.Other than that, the only other plausible explanation is crickets... ;-)2015 T@B Max S (320)
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
