Installation of Sofitel Sink
teztab
teztab Member Posts: 99
edited August 2019 in Modifications & Upgrades
I’ve just upgraded the sink in our 2018 320S with a Sofitel-style stainless sink and glass lid.  When searching the forum for any information, I found references to other members having completed this upgrade but no details, so I thought it might be helpful if I posted my installation experience.
The new sink is a Dometic / SMEV VA8005 which I purchased from Amazon for $219 + tax.  Installation took only about one hour, although that was made easier and quicker because I had previously fitted a Hepvo trap and flexible connector for the existing sink.
Removal of the existing sink was easily accomplished by unscrewing the four corner clamp wingnuts and breaking the fine caulk bead.  The faucet was then easily removed from the counter.  Since they both fit, I chose to transfer the drain and faucet to the new sink.
Perhaps the most critical part of this upgrade is the precise measuring, marking and cutting for the enlarged opening of the new sink.  There is minimal room for error.  I used masking tape to map out the opening.  Keeping the front edge of the existing opening I cut the sides, back and corners.  I offset the new opening slightly to the left, to allow for the close proximity of the right inside cabinet wall  and used my cordless jig saw for the cuts.
Since part of the existing faucet hole is exposed, I used epoxy putty to fill it (although the dark gray of the putty does not look so awful, I do plan mixing a little acrylic paint to match the counter top).  After checking for fit, the sink can be positioned and anchored down with the corner screws which are accessible from the top by removing the four rubber pads. Note, there are four tiny clamp extensions that should be fitted before dropping the sink in the opening.  Once the sink is secured the water lines and trap can be connected.  The final step is to run a fine bead of caulk around the sink (I used GE clear silicone).
The attached photos should be self-explanatory.  I am very pleased with this upgrade.  The end result is a flush, streamlined look and increased counter top versatility.  BTW, if anyone is in need of a standard sink and T@b inset board, I have them available in as-new condition!
⁹
  • 4ncar
    4ncar Member Posts: 1,072
    Nice look
    2018 320S Outback
  • jkjenn
    jkjenn Member Posts: 6,425
    Really nice work. Thanks for the write-up!
    Well done and good instructions!
  • morey000
    morey000 Member Posts: 162
    yeah- easier to install a new sink than to clean the old one.  ;)
    Silver on Silver, 320S '19 Outback
  • B0atguy
    B0atguy Member Posts: 268
    edited August 2019
    Looks great ! The counter top will be a much "larger" feeling space now !
    Luckily for us ,our standard 2019 320s (non Sofitel) , came with the Sofitel sink upgrade option .
    Makes that counter space much more usable, although I think the Sofitel sink is actually a little smaller than the standard sink ?  Any confirmation to that Tez ?
    One nice benefit to getting the Sofitel sink option from the "factory", is we still got the "T@B" cutting board !
    Some may not notice in your pictures, but the Sofitel sink has the faucet inside the sink , vs outside on the counter with the standard sink . ........... There is NO going back now !!!!
  • Estancio
    Estancio Member Posts: 243
    No doubt you will thoroughly enjoy the change!
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • teztab
    Now you have me concerned, @morey000 !  If I made installation seem that simple, I could be misleading lots of people! 😃
  • teztab
    Thank you @BOatguy.  As for size, overall, at counter level, the Sofitel sink is quite a bit larger than the regular one.  The initial recessed area is also larger.  However, the main part of the Sofitel sink is the same width but a little smaller front to back..
  • PNWtabber
    PNWtabber Member Posts: 492
    Very nice.  At some point, I can see me possibly doing this (as well as the plumbing modification).  The sink in my 2018 has no cover and, for much of the time is just wasted space.
  • VictoriaP
    VictoriaP Member Posts: 1,496
    @PNWtabber A cheaper solution in the meantime until you decide to tackle this project: https://smile.amazon.com/gp/product/B000EDUUGM/
    This cutting board fits the sink perfectly and doesn’t budge in transit. Many 320 owners also choose to replace their faucets, if the stock one bothers you.
    Pacific NW
  • PNWtabber
    Thanks, @VictoriaP.  Looks like a good solution for the near-term.  I have been looking at various cutting boards online.  Good to know this one fits!
