Just returned from a two-week, 5000km trip. Throughout the trip I only ever had to use my primary power cord to hook up, and had no problems. Today I tried to hook up to shore power at home, which requires the use of an extension cord. No power to the T@b. I've done this in the past, without a problem. I checked the extension cord with a multimeter, and had power. When I plugged in the primary cord, I couldn't get a reading - either because there was no power, or the probes on my meter aren't long enough for that yellow plug. In either case, when I hook up to the T@b the red light on the plug doesn't light up, and I get no reading from the 120 v outlets in the trailer. Is there a fuse I should be checking? I'm figuring I might have to take the primary cord someplace to have it checked out. It worked fine yesterday morning when we left our final campsite. Any help or suggestions would be greatly appreciated.
Bill & Helen; 2017 T@B S Maxx, (Serenity Now!!); TV 2019 Honda Ridgeline,
Woodstock, Ontario
0 ·
Since you have a 2017 T@B I seriously doubt your trailers power cord is bad, especially after coming off a 5K mile trip, etc. I would just try another electrical outlet in the garage (to test the cord and for peace of mind) or try resetting the home circuit breaker, using a different extension cord, etc.
The light in the 30A power cord "should" come on when it's plugged into shore power but the cord itself isn't internally fused and the light is just a visual help that indicates power is present. I'm assuming your trailer lighting is working fine and there are no issues es there? You do have a couple of 110V circuit breakers on your electric converter located on the bench seat of your trailer that you could check.
Other than the above, if nothing is working inside the trailer check the battery shutoff switch, the fuse at the battery and the fuses inside the electric converter to ensure everything is fine.
However - with the battery switch turned off, the lights, fan, and A/C fan (I didn’t turn it up to cold) all worked. None of the 120v outlets has power.
Mike, I checked under the driver’s side bench seat and didn’t see anything that looked like a circuit breaker. I assume I’ll have to remove the converter cover, but it looks a little daunting for my limited expertise, and I’m not sure I’m ready to tackle that.
Woodstock, Ontario
Circuit Breakers are on the front side, upper left, of the WFCO Power Center.
It sounds like:
- LED on 30A cord is dead or there is a bad VAC ground
- 12VDC Convertor is working since your 12V items work with the T@B Battery Switch in Off position
- VAC Breakers should be reset, as step one . . . easier than tracing a ground
30A Breaker Feeds to Convertor & the VAC breakers.
Since you have 12VDC the 30A Breaker is closed.
Woodstock, Ontario
So Use the Diagram as a Reference Not a Written in Stone Document
Woodstock, Ontario
Woodstock, Ontario
Woodstock, Ontario
Woodstock, Ontario
Once the front panel is removed you will have access to the breaker wire connections and can test with your volt meter. I had to replace my converter after it stopped supplying 12v power. It's not a bad job
Woodstock, Ontario
