I'm trying to determine which battery system does what, more specific..the 12 V installed next to the propane bottle appears to handle all lights, fans, door step light, etc. Is that battery charged while towing and/or when plugged into shore power? My confusion is from the owner's manual stating ALL power comes from the AGM batteries installed under the bed (part of the solar system), which obviously isn't the case. The owner's manual that came with the 400 is from 2017.
Does anyone have a schematic for the 2019 electrical system?
I called Customer Service yesterday mid-morning, left a message but never got a call back. What's the normal call back time frame?
Anxious to go camp but I want to know my systems first.
Thank you,
Toula
2019 T@B 400 -- 2017 Toyota Tundra
South Louisiana
1 ·
2018 Tab 400
2019 Tundra CM
Wisconsin
No, but the dealer added the battery as part of the "dealer prep" stuff. They didn't even know about the other 2 AGM batteries installed under the bed until we questioned them and then he called the company. We actually knew more about the 400 than they did. To their defense though this was their first 400 so we are learning together. Most of our knowledge came from watching Travels with Delaney on YouTube!
I just checked the front 12 V with a volt meter, 12.37 Volts ,(we took delivery 4 days ago). I turned on the battery disconnect switch and plugged into shore power.... it's now charging so I'm thinking it must be connected in parallel with the other batts.
Toula
South Louisiana
South Louisiana
If it were me, I would send pictures to tech@nucamprv.com and ask him for some help so the dealer can put everything back as it was originally. Be sure to include the dealer’s name so nüCamp can give them the proper documentation to put it back correctly.
And, I would get this done ASAP.
Many thanks for all the input!
I'll post a follwup when we get more.
Toula
South Louisiana
Toula
South Louisiana
Toula
South Louisiana
Welcome to the forum!
Toula
South Louisiana
