I'm just about ready to install the Lagun...I decided to put it inside so I will have some flat space. I want to install it on the driver's side bench and have been reading the 2x4 warnings for stability.   Mine (I bought it at least a year ago) came with different directions and attaches with bolts instead of screws. It came with 2 plastic angled shims and also has a large plywood plate that goes on the back side of the bench. DO you think that'll work as far as stability goes?
s?
Two bolts on left go through a block I added (3/4 plywood ok).
Make your added block as tall and wide as you can, and add some construction adhesive where added block meets up with any existing factory structure pieces.
If kit comes with big wood screws (as I recall it did) I'd switch to bolts with oval heads that sit down into plate, using washers and nuts inside box. Should be available at Ace or Home Depot type stores. You wind up with more holding power with bolt/washer/nut combination, though this requires finding appropriate type/length of bolts, etc.
Good luck.
I found it it helpful to use painters tape to securely mount the bracket and spacer in position then drilled pilot holes through the bracket, spacer, and trailer wall into the wood 2x4 bench supports. I hope this process will help you.
I am not sure about the two plastic beveled spacers. I bought the kit used and there are not any instructions. Can anyone enlighten me as to how to use them?
Thanks!
2022 T@B 320-S Boondock Edition
2022 Outback Limited XT
SOK 100ah LiFeP04 Battery
