I vaguely remember seeing a T@B 400 that had the arm of the torsion axle facing forward rather than aft as it should be. I haven't had the opportunity to see many 400's as the closest dealer is about 3.5 hours from me and I cannot run out and look at one on the lot. I would appreciate it if someone would look at their 400 (or any nuCamp teardrop, actually) and tell me if my memory is correct about the direction the arm faces. Unless I am remembering incorrectly (not unlikely) I wonder if the one I saw was installed improperly or if NuCamp has a specific reason to reverse the normal installation. I would think there would be suspension issues and brake issues if the trailing arm is in fact a "leading" arm.
As a side note, for anyone with an engineering type mind, the difference between the regular axle and the "pitched axle" used on the Boondock package is that on the regular axle the trailing arm is pitched 10 degrees down from horizontal and the "pitched axle" is pitched 22.5 degrees down from horizontal. Obviously, since the arm on the "pitched axle" is pointed farther down when at rest the trailer will sit higher than with the regular axle--thus the added 2.75" of ground clearance.
0 ·
Yes I am specifically interested in the T@B 400 axles. Nucamp told me that the part numbers for the two axles were 8136692 for the regular axle and 8136695 for the Bookdock axle. Those are apparently NuCamp part numbers. When I called Dexter the lady I spoke with said that both of those axles were #10F axles with xxxxx92 rated at 4000 lbs and xxxxx95 rated at 3900 lbs. That last bit of info makes me wonder if she had the correct axles--and thus the correct angles. A net 45 degree change would seem more likely to provide the increased clearance claimed. However, I don't think the change in clearance is 5.2". I measured a diff of 2.75" when I had an opportunity to compare a regular trailer with one with the Boondock mod. This was on a dealer lot so I doubt the difference in weight as they sat there could have been very much if anything.
Michigan_Mike--
Thanks for checking. Either I got myself turned around crawling under the trailer in the hot Texas sun or there is at least one trailer existing with the axle installed backwards.
So now I wonder if it would be worth the effort to get the Boondock axle on a T@B 400.
