Exactly, I want to have to bring as little as needed with me. One less thing to worry about. That is interesting about the humming issue. I'll have to see if that happens to me when I get it as well.JohnDanielsCPA said:No doubt, the progressive industries EMS is best in class for 110V protection. I have two for my fifth wheel. One is a portable and the other is the hard-wired as you are showing.
I upgraded to the hard-wired for simplicity; I didn’t want to worry about someone walking off with my portable and to reduce setup and teardown time. One thing I will warn you about; the hard-wired has a tendency to hum. Mine does, and it can be very annoying at times. My fifth wheel is in the shop right now to fix a broken shower panel, but I asked them to take a look at the EMS to see if there is anything they can do to reduce the humming noise. The technician was not hopeful, but said he would take a look at it. I did call Progressive Industries some time ago who advised the hum could be reduced by dismantling the EMS and cleaning out the “coil?” That’s beyond me.
Anyway, just a note . . .
That might be kind of hard to do since the romex wiring comes right from the side of the T@b directly to the WFCO box. It would mean re-routing all the wiring. Its possible I can mount some sort of rubber or foam isolator under it to minimize any humming. Seems like it shouldn't do that though. Perhaps there is an issue with it if it hums that loudly. All it is a small board with some heavy duty MOV's on it and some circuitry for monitoring and a contactor inside. Its possible that the coil in the contactor is messed up, AC units also have these contactors and usually don't hum when engaged.Sharon_is_SAM said:Maybe if you can install it somewhere in the cabin away from the bed. In the U/S model maybe in the closet or cabinet next to the sink or over the counter. In the CS model, maybe under the front counter or in a galley cabinet that does not get hot from the Alde. I think the converter fan can annoy people as it is.
Actually I was planning on installing it on the 2x4 under the driver side wheel well right next to the WFCO box. There is a wood divider keeping it away from the ALDI system so it should stay fairly cool. Also I don't think there is too much to get hot, the contactor is like a big relay and has a electromagnetic coil that sucks the contactor down when engaged. This is used to break the connection to shore power is any of the over-voltage or over-current or open ground conditions are met. Its possible that coil may get a little bit warm as it is like a relay, but it should not get very hot. When I get mine installed I will post some pictures and I also have a Flir thermal camera so I can take readings on it to see how hot it gets.Sharon_is_SAM said:I wonder if the installed EMSs get too warm installed under our benches with exposure to Alde heat.
Thats great to know! I have a feeling the isolators they are referring to is a vibration isolator. Perhaps something like these washers would fix the issue or make it much less noticeable.JohnDanielsCPA said:I don’t think you will have problems with heat in that location; seems the perfect spot to install it. I will also say the hum from my EMS is not impacted by heat; the hum starts immediately when the EMS is powered, so it’s something within the EMS itself. Also, I didn’t want to give the impression that the hum is particularly loud. With normal background noise, you probably wouldn’t even notice it. But when it’s quiet, you can hear it. Progressive Industries told me installing isolators would reduce the humming sound. I haven’t got a clue what those are nor where they would be installed! If anyone knows, I would love to be enlightened. Regardless of all this, I am very happy to have an EMS. I have run into a fair share of badly wired campgrounds; my EMS saved my rig.
