Hitching up?
The T@B is aluminum. The Outback Rack (yakima) is coated steel and it will attach to that. Even putting a small steel plate attached with zip ties would work well. That said, aluminum interferes with the wireless (bluetooth) connection, so if you have an all-aluminum TV like my F150 and your camper is aluminum (the T@B body is), there's a chance it'll cut out just as you try to miss that tree for fence post you were trying to avoid. I say this because it did exactly that. I was thinking of getting a post I could tap into the ground with a small steel plate that could take a wide angle view of the campsite (or my horrid driveway). It's on my To-Do list!! I'm not giving up on that camera.SueBC said:Wondering if anyone uses RVS-83112 Wireless Hitch Camera. I don't yet have one, but am thinking on purchasing for when I am hitching up (flying solo). It is totally wireless, and attaches on stuff with a powerful magnet. For hitching up, and backing up into a campsite, could be a nice little 'assist'.
Just my experience!!!! Yours may vary. Other people may chime in and say it's the next thing since sliced bread. You can always return it, right?2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)1 -
It took me a while to get the hang of it, too. My first TV was pretty close to exactly the same width as the T@b, so it made it easy to get square. I then used the bump it rods and they work pretty well. The back up camera helps, but in harsh light or heavy shadow, it can be difficult @Verna put some reflective tape on her coupler and I tried that but it would not stick. I think my tape was too stiff. I picked 7p a swift hitch and I put it on the coupler because it is bright yellow. My backup cam picks that yellow up, easily, so maybe a bright yellow magnet would work, as easily.
Our van backup camera is not directly in the middle (more on drivers side due to the hatch latch) so it is not as easy to line things up. I think we may need to try the bright yellow magnet trick.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
I think the Bump-It's I picked up were $4.00 on sale so if they work, I'm set, but if not, it's nice to know there are a lot of options.0
Take it slow & easy. Stop and get out of the car to see how you’re doing. One of the nice things about the T@B is that the tongue can easily be pulled from side to side. So if you’re a little off, just pull or push the tongue to center on the ball.2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN2
As long as you're using the jockey wheel, true. I don't use the JW and have a foot mounted on mine so that I can crank the jack up tighter to the frame area. I also carry along a chunk of 4x4 treated wood to place under the foot that helps eliminate some of the manual hand crank work.GibW said:Take it slow & easy. Stop and get out of the car to see how you’re doing. One of the nice things about the T@B is that the tongue can easily be pulled from side to side. So if you’re a little off, just pull or push the tongue to center on the ball.
I also really like and appreciate the luxury of the camera on the tailgate of my Silverado and make it a point to keep the lens clean as it does collect dirt, moisture and particles (dirt tends to distort the view) and ensuring that it's clean makes hooking up the trailer easy-peazy. It certainly eliminates the in and out checking of alignment and over time one can become pretty adept at this task and comfortable via the repetition.
But agree, take it slow, do what works best for you and makes you feel comfortable and confident and make sure the hitch is properly seated and (for newer style T@B units) that the locking mechanism and prongs at the bottom portion of this mechanism are properly seated into the small square opening and that this mechanism is either pinned or locked in place. I make it a point to check ball/hitch alignment and final positioning visually and physically and I know that some people run the jack down and raise the rearend up to ensure things are hitched properly.
Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ1 -
It has been mentioned before about using a rock or kick mark to guide you, what I do for all trailers I tow is carry a short piece of a 4x4 wood block, when you think you are close, stop and look and if you want to get real fancy, measure the distance to go with a tape and then place the block of wood that same distance behind the TV left wheel, back up until you make contact and the ball should be under the hitch assuming you are centered side to side. The leave the block there when you unhitch and as long as it doesn't get moved, hooking up again is simple.
As far as wheel vs plate on the hitch jack, I remove that on any trailer I tow (not exclusive to NuCamp products) and place in trailer, gives a lot more ground clearance when going through dips.2019 T@B 400 Boondock Lite0 -
@Michigan_Mike... I also use a jack foot. Our tongue weighs in at about 200 lbs and is still very easy to move from side to side with a little persuasion. I also put a block under the jack foot and will slide from block to block if needed.2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN0
My 400 weighs in at over 350# tongue weight so the play isn't there. You're either pretty much right on or you jockey for position and let the truck do the work.GibW said:@Michigan_Mike... I also use a jack foot. Our tongue weighs in at about 200 lbs and is still very easy to move from side to side with a little persuasion. I also put a block under the jack foot and will slide from block to block if needed.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Hey Mike:We just bought a 2018 Colorado in June. During my initial visit with the sales guy I was asking questions about towing and during the exchange he showed me how to partially drop the tailgate so that the camera looks more downward toward the hitch area. This may also work on your Silverado tailgate: just open the tailgate a few inches and loop the supporting cables over the round locking posts on the side of the tailgate opening and then let go - should keep the gate open at about a 30-45 degree angle and also keep it high enough so you don't bump anything with the edge of the gate while hooking up. The field of view is large enough to allow last few feet to make adjustments for perfect alignment.I tried it and it works well and can often place the ball right under the coupler.This may work on other manufacturer's vehicles??John & Cheryl
2018 Chevy Colorado V-6
Edmond, OK3 -
I like that! I will check it out the next time we hook up which will be soon! Thanks for the great tip!cmac said:Hey Mike:We just bought a 2018 Colorado in June. During my initial visit with the sales guy I was asking questions about towing and during the exchange he showed me how to partially drop the tailgate so that the camera looks more downward toward the hitch area. This may also work on your Silverado tailgate: just open the tailgate a few inches and loop the supporting cables over the round locking posts on the side of the tailgate opening and then let go - should keep the gate open at about a 30-45 degree angle and also keep it high enough so you don't bump anything with the edge of the gate while hooking up. The field of view is large enough to allow last few feet to make adjustments for perfect alignment.I tried it and it works well and can often place the ball right under the coupler.This may work on other manufacturer's vehicles??Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Just don't bash your tailgate into the jack!2019 T@B 400 Boondock Lite0
I learned my lesson the hard way 2 years ago out in Havasu SP. I was dumping the trailer after we left Craggy Wash BLM, was working in the bed of the truck, had finished putting the hose away when another RV'er pulled up behind me. In my haste to move, forgot to put the tailgate up and crunched the top lip, damaging the plastic cover, costing me $100 to replace it. Nothing like spoiling your whole day!N7SHG_Ham said:Just don't bash your tailgate into the jack!
If ya do as I described, the tail gate will not be down far enough to contact anything, only give ya a better viewing angle of the ball and coupler.
John & Cheryl
Edmond, OK0 -
I can report that I have now used the Hitch Camera I bought - RVS-83112 Wireless Hitch Camera - a few times, and I love it! I do use it only for hitching up, and still take it slow, and when according to the camera I'm really close, I do pop out of my Jeep just to take a quick look. Every time I have been dead on side to side, and just nudge the jeep back another inch or two. Never had to pull away and try again, its always first time round success. For me, - single camper - works like a charm.
SueBC
British Columbia, Canada1 -
I hitch up solo all the time without a camera. My pickup (an F150) is exactly as wide as the trailer so going straight back is easy, but I’ve come in at an angle too. I get lined up and start backing up. When I start getting close I get out and look. I make a mental note of how far left to go, say five feet. I just eyeball it. Then I open my door and look down at the ground. I back up looking at the ground and go about five feet. I get out again, now it’s six inches. I look down at the ground and go six inches. This time when I get out, I put it in park and set the brake. Now one inch. It takes me three or four times hopping out and takes just a few minutes.2
my truck has a back up camera with side lines and the hitch clearly visible i put a piece of silver duct tape on the hitch ball area of the camper's hitch so i can see when i am lined up easier-truck tends to roll just a little so i put on emergency brake before turning off-voila!-if not perfect i can move the trailer a little with the handles or grabing the hitch1
I use "Hitchin Rods" and they work every time. They are kind of expensive since they tend to get crunched under the wheels when they fall down!
2021 T@B 400 Boondock Solo1 -
Speaking of hitching up, here's my latest modification. I painted the coupler lime green to make it easier to see.
5 -
Thanks! I was so happy to finally get rid of that broken tub. It's a miracle that it didn't fly to bits while I was driving down the freeway.dsfdogs said:Good idea @Marceline! Nice new tub too.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
2 -
Good idea. I could never get reflective tape to stay, like @Verna but I have been sticking my bright yellow magnetic camera back there as a marker. The coupler gets list in the backup camera's shadows.Marceline said:Speaking of hitching up, here's my latest modification. I painted the coupler lime green to make it easier to see.
@jkjenn, the reflective tape is not staying on as well on my 400’s coupler as it solid on the T@B S Max, but it’s still on there. @Marceline, I may have to try that color after I find some warmer weather.Verna, Columbus, IN
I have a bright yellow piece if cloth I lay on the hitch to help me see it with my back up camera from my TV-the black hitch is almost invisible to these old eyes3
I am so glad this came up, again. I need to get on this.
kaylevine1 said:. . . bright yellow piece if cloth I lay on the hitch to help me see it with my back up camera from my TV-the black hitch is almost invisible to these old eyesGreat idea!
I've added white paint to my coupler but does not really help - - -
I've also got glasses So it is not my eyes it is the backup camera!
I cut a small wedge out of a yellow tennis ball and slide it it on hitching ball. Super easy to see and I slide it off when I am lined up.Kr@cken
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa1 -
I am taling another stab at those rods while on vacation, next week. My 1st Grand Cherokee had a better camera for high contrast scenes than my Trailhawk has and I really struggle in bright sun with harsh shadows. Instead of the rods with tennis balls, I am trying the Hitching Rods brand.
Are you struggling with side-to-side alignment or distance from the ball to the hitch?jkjenn said:I am taling another stab at those rods while on vacation, next week. My 1st Grand Cherokee had a better camera for high contrast scenes than my Trailhawk has and I really struggle in bright sun with harsh shadows. Instead of the rods with tennis balls, I am trying the Hitching Rods brand.
For alignment, I know the centerpoint of my TV back window (backup light) and the centerpoint of the trailer (the "@" in T@B but you could put a cute little sticker or something) and I just align them as I'm backing up.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
