@Jdcouple The only drawback I can imagine is it would make a change out to a jackeup type of jack impossible, due to the three bolt design. Does that seem right to you?
John, Judi, Guinness & OD in PDX T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner
I was stuffing it in to the front box until I lost one. I was putting it in the back of a truck till I lost one. I was putting it in a trash bag (most recent) puke! We will see. This might not be perfect either. Lol but it's perdy and only cost me about $30 (had scraps of dimond plate and expanded metal left over from another project). Someone used to sell a kit for doing this and it was really nice but really expensive.
Nice fix, unfortunately, we have a 320 CS-S so that area is where our spare is. I did find a solution. I mounted it under the tongue and painted it black. It's about 1" lower than my black/gray connector. Here are the parts - I decided NOT to add the gutter pull out.
Sewer Storage 1 Gatehouse Arborley 5x5x96 White Fence Post $24.97 #17708(Outside in the garden fence section) 1 Genova 4 1/2 inch White Vinyl Gutter $6.47 #12066 (Inside lumber section) 1 Gatehouse 5x5 White Pyramid Post Top $ 3.10 # 87410 (With the post in garden section) 1 Fiberon 4x4 White Composite Post Cap $1.98 #100437 (With the post in garden section) 2 USP1 1/4 x 24 inch Light Capacity Strap $1.53 Each #51572 (Across from vinyl gutters) Rubber Washers Rubber or installation between the straps and fence post
T@B 320 manuals and electrical drawings Considering a 2024 TaB 400 with all the option packages (full lithium), 2023 Jeep Gladiator Sport S, Max Tow Package.
For Klenger. Here is a side photo of our setup. To be honest, this view is not flattering but up close it looks like a factory install. We've been on two trips since I installed it and it's worked great. We are trading this 320 CS-S for a new 2019 400 boondock that we hope to take delivery of in April. The new 400 has the spare mounted under the tongue, so I'll have to look for a new location to mount the sewer storage tube. I remember seeing someone had mounted exactly where I did in the photo but on top of the tongue. FYI, the 400 doesn't come with the platform, but our dealer found a craftsman who will make a custom aluminum for us.
@Blueespy, just a note. The reason the 400 does not have a platform is that they are tongue heavy. Tongue weights are reported as high as 450+ lbs dry. Adding a platform and cargo to that may exceed any safety margin built in to tongue weight/frame capacity, although I am not an engineer.
I ended up taking a rather severe modification to all storage on the a-frame and I am very pleased with the final outcome. I just finished it today. Check out the pictures at the link below. These pictures are before it was complete, but you can get the idea. It's a rather pricey mod and took a fair amount of work to finish it. but that's the way I roll. Sewer hose storage is between the tool chest and the front of the trailer. It fits perfectly and is almost totally out of sight. http://www.klenger.net/storage.html
@Blueespy , [IF YOUR ENTRY ABOVE WAS A PREVIOUSLY DATED "CUT AND PASTE," YOU CAN DISREGARD THIS POST]: I do not own a 400, but nüCamp has added a sewer hose storage tube to the 2019 model. From what I have surmised from reading posts on it, it spans the width of the camper near the back end in a lower compartment. Others can correct me if I am wrong, but I believe it is contained between the two sidewalls of the camper and includes screw on/off covers at each end of the tube. It will hold a 15' Rhinoflex hose and attachments.
Rubber Washers
