Has anybody upgraded to a 8,000 btu Air conditioner
Talan
Member Posts: 11
My 5,000 Danby Air conditioner does not cool during the day Yes the Vent fan is on If it's 90 outside it's 80 inside Yet at night it will freeze you out and cool down to 68 during the night I would like to install the Kenmore 8,000 btu digital remote Has anybody updated to a 8,000 btu unit and did you have room to trim the cabinet to install it What about hooking up drain hose to the new A/C Any information greatly appreciated
I own a 2017 T@B Max S Thank you
Before you do the change, try one more thing, please.
Open one side window (the non-sunny side) to the first open position (open about 1” or so), and lock into this open position. Then open the roof vent about 2”, and do not turn the fan on.
See if this helps cool the T@B better.
This is how I cool my T@B cool enough for my dog who hates getting hot.Verna, Columbus, IN
I'm contemplating something similar (LG, GE, or Frigidaire). The pan leads to the drainage tube. There's some 6000 BTU higher EER units that look like they could be made to fit in the box with surgery on or replacement of the front plate. But most of the 8000s look to be a bit too tall without changing the box. Let us know what you go with, if @Verna's window trick isn't enough in your climate. @Verna also suggested getting a replacement model with an echo / power saving mode, so you don't freeze once night sets in.2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
Former steward of a 2017 T@B S Max1 -
"eco" not "echo".2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
This has made a big difference in the Efficiently of ours cost about $4.
- Hash T@B Fun
6 -
Ditto to what Dale does. Works very well for us, too.2016 T@B 320 Max S "T@BsentMinded"
2009 Subaru Outback R 3.0
2022 Ford Ranger XLT Super Cab
The adjustable vent air diverters are a brilliant idea!! Cheap and an amazing difference. Very easy to find at your local box store too.2017 820R Retro Toy Hauler from 2015 Tabitha T@B from 2009 Reverse LG Teardrop (but a T@Bluver at heart)0
I have adjustable diverters INSIDE not outside... so I'm curious, how do you keep them on? I know 9 times out of 10 they're magnetic, so does this mean y'all have to take them off after every trip?
Look out open road, here we come!!! Me, my Gracie May, a 2YO Beaweenie; half Beagle, half Dachshund, Dash, the 2015 Kia Sorento LX V6, Gidget, the 2018 nüCamp 320s!
Metal strips attached with 3M tape
- Hash T@B Fun
Freezing is never s problem for me...DougH said:@Verna also suggested getting a replacement model with an echo / power saving mode, so you don't freeze once night sets in.
I'm confused (not a new issue) How do the diverters on the outside exhaust vent help keep it cooler inside. My Danby struggles to cool the cabin in the Texas heat. What should be the differential temp between the incoming air and the outgoing air flow?Gerri (Gary) Ewing
2018 320 S - "No Agenda Hacienda"
Tow Vehicle 2023 Honda Pilot AWD0 -
For the AC to work effectively it needs cooler air on the side intakes. Without the diverted the very hot exhaust air is sucked back into the unit where it becomes even hotter.
- Hash T@B Fun
3 -
Just to clarify - You are saying that the hot air exhaust will flow out the area between the two diverters, while cooler air will enter thru the two diverters -
Correct?
Thanks in advance..
Gerri (Gary) Ewing
Correct
- Hash T@B Fun
We used our deflectors the last few days. Helps a lot!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
Any tricks for keeping the humidity down? Up here in CT right now it’s been very muggy, running the AC works great but after it reaches temp and shuts off the humidity climbs like crazy!0
We open our fan vent and crack a window or 2. It keeps the air moving and feels less humid.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
I live and camp in Southern California. I’m in the air conditioning business. My TAB Outback with the 5,000 BTU does not cool comfortably if outside temperatures are above 90. Unit should have been minimally a 6,000 to 8,000 BTU. If humidity is high it’s even worse.0
@Joelair1980 : I replaced the original with an LG 6000BTU unit. Has a dry mode, and also cools better. Only problem is it's a slinger type, and sometimes leftover water can get back in the cabin. It's on my to-do list to remove the plug and see what the impact to cooling efficiency is on this model.2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX
We shouldn't have to go thru all this trouble to stay comfortable They over charge for the price of the T@B models They could put a better A/C unit in and a better heating system... (Language edited by moderator.)I got tired of being hot in the summer and cold in the winter Sold my T@B I now on a 2019 Little guy Mini Max A/C works great 13,500 btu Has a furnace in it that works just like central heat Instead of heating system that heats up anti freeze and won't warm up a T@B Good luck to all of you0
@Talon, I'm sorry your T@B didn't meet your expectations, and am happy you found something that works better for you.I do recall from other discussions that you experienced some frustrating issues with your Alde. However, yours did seem to be an unusual case that was not reflective of Alde quality in general.2015 T@B Max S (320)
97 degrees in Alabama the other day....was cool during the day and night. I do use the air diverters. No shade either at least on the camper.0
That is HOT! The diverters do help.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Yeah the South is ridiculous.....0
- 30 "FOR SALE" - New/Used Trailers
