Only the middle setting will allow for cabin heat. There is no "warm water pump"--the upper setting turns on the heaters without circulating the glycol. This allows you to have hot water without also heating up the cabin.norwood said:...Should the heater circulation pump be switched off (bottom), normal (center), or warm water pump off (top)?...
I was under the same impression about only using the 1kw setting if plugged into the 15 or 20 amp circuit. Then I was on the Alde website and it says the following "Max draw from 120 V mains is ≈4.5 A on 1 (1 kW) or ≈9 A on 2 (2,1 kW)"Sharon_is_SAM said:@Harwoodmary - as long as you bypassed the Alde water tank when you added antifreeze to the plumbing you can use the Alde to heat the cabin. If you are using a 30 amp outlet for shorepower you can turn the Alde up to 2 and to heat it up faster, you can add in propane. If you are at home and only on a 15 amp circuit, then you are limited to the “1” Alde setting. If you are plugged into a 20 amp circuit, then you can use the “2” setting. Just be aware that you won’t be able to run another heat generating appliance like a microwave or a hair dryer as you will trip a circuit breaker.
There are two mechanisms in the Alde Compact boilers that draw >0.1 A current from the vehicle 12-volt battery. The exhaust fan venting waste gases (≈0.4 A), and the heating fluid being pumped around the circuit (≈0.2 A). So normal draw from the vehicle battery is between ≈0.2–0.6 A, including the control panel. Max draw is 1.9 A for approximately three seconds at system start-up.
Like others have said it may appear that a 20amp circuit is the minimum safe bet to use the 2kw setting.
