I have just discovered the Zero G hose and found various reviews on Amazon and RV discussion forums with the rating split about 50/50 between good and bad.  Also in the recent Trailer Life magazine Camping World has them on sale for $23.99 for a 25' x 1/2" size.  I will be using it with a pressure reducer at the faucet and another one at the trailer entry point.
Sooooo, my question to you is do you have one or have you tried one and what do you think about it as far as using it for your T@B trailer?
Thanks in advance for your comments.
John
I think it is a great hose because of the small footprint it uses. Hopefully they will remove the restrictions on it’s usage.
J.D. & Sue
This is the bag I use to store my fresh water gear and it goes inside a gear tub. It's a cloth-like material so I still screw both ends of my hoses together to avoid water leaks. I put all the fresh water accessories into a smaller bag inside.
Sold 2023 Tab 400
Sold 2018 T@B 320S
2018 Chevy Colorado V-6
Edmond, OK
Actually, I’ve just reversed the brass Y connector, putting it after the water filter. The first pic is the brass 90’ elbow at the intake.
@cmac have fun with the new hose! I might suggest having a second one as back up, in case 25' isn't enough or if it springs a leak. I too LOVE how light they are and easy to manage.
Sold 2023 Tab 400
Sold 2018 T@B 320S
Edmond, OK
Edmond, OK
Too use a Y fitting at the hose bib, then pressure reducer. I have fitted a “whole house” filter system and have a short section of “white” hose a fixed to the fresh water inlet, utilizing the 90* brass fitting.
ps. I ordered a visor from your Mom!
Sold 2023 Tab 400
Sold 2018 T@B 320S
Edmond, OK
The reviews were either really, really good or really, really bad.
That said, I sorta like the dual water pressure regular setup. As the daughter of an old programmer, I believe in backing up backups.
Edmond, OK
@jkjenn Glad you liked them! I'm still using both of mine too. I have not tried the dual pressure regulators.
@cmac I'm glad they are working so well for you. I like the idea of the quick releases, thanks.
Sold 2023 Tab 400
Sold 2018 T@B 320S
