we are in a T@B 400. Currently in the high desert in Likely, CA. Temps have been in the mid 20s at night. The Alde works all night, set for70. If outside temp is 24 we can get to 64 inside, if outside is 28we can get 68 inside. We are snug under a quilted cover, so this not a significant issue. I’m just curious about what the Alde system can do. If this is not “normal” what might be going on? We only use the electricity option.
0 ·
Alan & Patty
Southern Az
I agree with others, be sure the heat circulation vents are not blocked, be sure that you're using the high wattage setting with electricity, and add propane to 'boost' the output.
Also be sure your glycol is up to level.
The Alde screen has the option to ”true up” the temp on the screen if a known accurate thermometer shows a different temp. The option is called “ Temp Offset”.
