About this time last year, I posted a tutorial on how to winterize our TaBs for the novice owner. We just finished the task and I have updated the 2018 version. It went much easier this year and I think I simplified the steps for ourselves and everyone:) I will see if we can replace last year's version. Hope this helps!
Sharon
8 ·
J.D. & Sue
J.D. & Sue
In the instructions I created, I noted that it was helpful to pressurize the plumbing system using the pump prior to emptying the Alde Hot Water Tank. If you do this, you should get a more rapid emptying at least initially, then it will taper off. Just be patient and let it drain. Raising the tongue may speed things up, too.
Sharon
I know @Verna has used a bike pump - not sure if she had another pair of eyes to help or not. We do it at home with the TaB plugged in, then we plug in the compressor into the 12 v outlet in our rear galley (CSS). I can tell you that the pressure does not rapidly rise, so I think if you had to do it yourself, you could watch it rise up to 40, then open the tap - easy. I think if I only had the one faucet, a bike pump would do it. Just get it up to the pressure you need then go inside and open the tap. You may have to do it more than once, but that won't take long. And I would save the vodka for a martini. Use the pink stuff:)
If you buy the $50 Slime tire inflator from Walmart (approx price), you can open the front window and slide the cord inside to plug into a 12V outlet. Or, Battery Tender has a 12V plug that can be attached to the battery in the front tub, if that is easier.
I got ahead of myself and did my antifreeze in the pump technique with pieces of tubing with screw-on fittings at the ends, before doing the blowout..
Then when I connected the air compressor to blow out the lines, the disconnected water line from the right/exit side of the pump started hissing at me, reminding me that the backflow check valve that isolates the two water supplies is inside the pump, not the line. I temporarily plugged that disconnected line in order to finish blowing out all the other lines.
Hopefully next year I'll remember to do the blowout first before doing the antifreeze in the pump. This is only my second time winterizing, so not quite automatic yet. I did leave the 3 Alde bypass valves set for bleach sanitizing in the spring, so that was a good tip to learn. Thanks again.
