I'm trying to follow the
"Travels With Delaney" video dealing with winterization. Patrick has a T@B 400 with an Alde 3010 and uses the Camco 36543 Winterization Kit to add antifreeze. I'm having trouble finding out where to install the that kit's valve on 400 with an Alde 3020. Can someone please provide guidance?
I don't plan to use the blowout method for winterization. Thank you.
Mike & Cathy
2019 T@B
Crestline, Ohio
2019 T@B400 Rogue
2012 VW Touareg 3.0 TDI
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
2019 T@B400 Rogue
Unrelated news. You don't have to loosen screw to adjust temp on mixing valve but the knob is hard to turn.
2019 T@B400 Rogue
2019 T@B 400 BL
2019 T@B 400 BL
2018 Nissan Frontier
Kennebunk, ME USA
I would demand that your dealer get on the phone NOW to Nucamp, explain to them what they did and get a fix for it now. I would also expect the dealer to extend the warranty if needed to cover you in case it's too late and the water tank has frozen--which you won't find out about until you go to add water to the system next spring/summer. Geezzzzz---why are these kinds of dealers allowed to even sell these Tabs? Do they not have to have ANY knowledge of the plumbing system?? Appalling.
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
Kennebunk, ME USA
In the spring when you sanitize, close your hot and cold water drain valves and your hot and cold water Alde supply valves, and open the bypass valve (see picture). By doing this, the bleach water will move from your fresh water tank, through your plumbing lines and avoid the Alde tank. After you rid your TaB plumbing of the bleach smell with multiple rinses, then you can put your valves back to camping mode. (Yes, the valves are in the same position for those who want to actually fill their plumbing with antifreeze - same effect - bypass the Alde tank.)
Kennebunk, ME USA
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
