Hello everyone. I have a 2016 T@B CS-S Max (clamshell) with the Alde system and I’m having a plumbing issue. For some reason I am getting intermittent hot water coming out of the faucet when I have the cold water turned on. The cold runs for a second or two and then hot will run for a second or two. The only thing that I’ve done that may have caused this is winterizing but I feel like I winterized correctly, based off a manual I found online. Can you think of anything else that could cause this? Bad mixing valve? Thanks.
0 ·
If the bypass valve checks out, than I would turn my suspicions to the mixing valve.
Good luck and please let us know what you find.
2019 Ford F-150 3.5L Ecoboost with Long Bed
Never mind, just saw how old this is.
Alan & Patty
Southern Az
This is the only one I can find. We need some creative 400 owners to step up here😊
https://tab-rv.vanillacommunity.com/discussion/7334/tab-400-wiring-and-plumbing-diagrams
@ScottG, can you add this to the User Manual/PDF thread, please.
https://tab-rv.vanillacommunity.com/discussion/comment/36103#Comment_36103
