Did the glycol exchange. It was really no big deal.
1. pull the plug and drain the old glycol
2. rinse out the system with distilled water
3. tip the tongue up and down to make sure the lines were empty
4. poor in the new glycol
https://www.amazon.com/gp/product/B01BDWQXM2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=15. tip the tongue down and open the bleed valve in the back under the shelf passenger side
6. tip the tongue up and bleed again
7. start the Alde to make sure it is working
Pretty easy
2016 Max S
Kalamazoo Michigan
2016 Max S
Kalamazoo Michigan
There's one part of my system that won't drain by tipping it up and down and sideways and shaking it. That would be under the driver side bench below the AC unit. (I've been thinking of adding an extra drain port on that heating loop).
I realized it might be a problem when I was only able to extract a gallon or so from the system.
Then when all finished refilling, and I tested the glycol for freeze protection, as @Sharon_is_SAM noted, it was quite diluted. That's why I had to add extra 100% glycol, to get it back down to good freeze protection.
But I thought I read that the newer Tabs don't have a heating loop underneath the driver side bench? if that's the case then the glycol capacity of the newer Tab would be different from the capacity of our Tab.
Then the only real answer would be to test the freeze protection. (Note that you can't use a standard ethylene glycol hydrometer to test. You need to test it with a refractometer)
jeannie
2016 Max S
Kalamazoo Michigan
Per Creed at nuCamp:
Q: When doing an Alde glycol exchange, how much volume is required to fill the system?
A: You will need about 3.5 - 4 Gallons for the Tab 320 and 4 gallons for the TaB 400.
Q: Will the system drain completely via gravity? Is a device required for draining/filling/both?
A: The fluid will drain once you remove the Low Point Alde drain plug - it will have a red plug and an Alde hose clamp holding the plug in place.
As I said, the newer models, I thought I heard, don't have the troublesome (for me) radiator under the driver side bench seat.
Maybe NuCamp figured out that it will fully drain with the different configuration. Admittedly, ours was one of the first with the Alde system.
I included the 400 info in my post above.
Maybe Creed is 'new' at NuCamp and hasn't seen the earlier Alde system that has the extra radiator under the driver's side bench? Or maybe the later Alde installation was done with draining in mind?
Or am I wrong that the newer 320 only has the right hand radiator and the rear radiator? (It's one of those 'I 'thought I read somewhere' things...
So that's the Alde radiator loop I was unable to gravity-drain. I think I might have been able to get it all out if not for that one (though definitely a little tricky with all the tipping and tilting and shaking)...
I have been tempted to extend that loop into the shower, and put in the radiator like the 400 has! Fancy schmancy!
2016 Max S
Kalamazoo Michigan
"Does Pleasant Valley Repair department use the special Alde pump when they do a requested glycol exchange for TaB owners?"
Answer:
"It depends a bit. If the glycol is not bad yet then we would just drain it and then refill. We have a special pump from Alde to aide in this process but it is not mandatory. If the glycol is bad we would remove the inlet & exit lines on the expansion tank rinse the lines out followed up with air to clear out the water. But you can simply drain the glycol & refill it with the gallon containers as well with no issues."
Good to know nuCamp has the pump. I see lots of Alde glycol exchange requests for uCamp 2019!
required to refill— he states you can simply drain & refill, but again it has been stated in posts here that only 1 gallon will gravity drain. Or am I still not understanding something?? Wouldn’t be the first time I have been confused 😐
