Smoke Detector and Battery Cut-Off
I only started noticing this, this year, but when I have my battery switch in the off position, my smoke detector beeps. After I turn the battery on, no beeping. I get that the smoke detector needs 12v power to work, but it must be getting some battery to be able to beep. Any thoughts? I tried to see if there was a backup battery but the cover of the detector does not seem removable. Anyone have experience with this? (2015 320 S Max)
  • Not sure if they used the same one in my 2018 400, but I just ran into a smoke detector beeping thing.  It really fought me trying to remove it from the wall.  Finally, the cover popped open and I was able to change the 9 volt battery inside.  No other wiring, so it's just the 9 volt.
    2018 T@B 400
  • Our CO detector is dependent on 12 v and effected by our cut off switch, but our smoke detector is run by 9 volt only.  Any pictures Jenn?
  • ChanW
    ChanW Posts: 3,165
    edited December 2018
    Jenn, you mean the thing on the floor, or up by the AC unit?
    I'm with @Sharon_is_SAM - the smoke detector, near the AC unit, is independent, with a 9v battery.
    With the CO/propane detector, I think we've had it beep on low battery (scream is more like it, freaking out the dog), but nothing once the battery was unhooked.
    ScottG Posts: 5,688
    Ditto that.
    My smoke detector (the thing up the wall above the window) runs solely on it's own 9V battery.
    My CO/propane detector (the thing under the bench) is hard wired into one of the T@Bs's 12V circuits and does not appear to have an internal battery backup.
    Unless your 2015 has different components form mine (always a possibility) I'd say yours is haunted.  :-0
  • mona
    mona Posts: 246
    Mine is the same as ScottG’s.
    2015 T@b S Max  white with silver trim. 2018 GC Trailhawk.
  • BrianZ
    BrianZ Posts: 1,770
    edited November 2019
    As I recall, @jkjenn,  we normally must squeeze two sides together while pulling towards you to swing the lid open to get to the battery.  Here's our Instruction sheet..
  • OK, what is special about a smoke alarm for an RV--as opposed to any other smoke alarm?  BRK's product literature makes a point of saying it is "approved for RV's."
  • rfuss928
    rfuss928 Posts: 1,190
    In my T@B the unit near the floor is the propane (combustible gas) detector.  Both the smoke and CO detectors are mounted on or near the ceiling.
  • Mouseketab
    Mouseketab Posts: 1,262
    Same here for my 2007, but my original ones died, so I replaced them with a combo smoke/CO detector on the wall. I brushed the carpet on the ceiling a bit and you can't even tell the smoke detector was ever there. I'm sure it's getting close to time to replace my propane detector.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
    ScottG Posts: 5,688
    IIRC the propane and CO detectors are combined in a single unit (the one near the floor) in the newer T@Bs
  • jkjenn
    jkjenn Posts: 6,424
    OK will take another look in better light. ..finding good light is hard on these short days....especially with the little amount of sun we get. I thought it had it's own battery but when I could not get the cover off I figured I was wrong.
  • jkjenn
    jkjenn Posts: 6,424
    Thanks to @BrianZ for posting instructions. Mine disappeared a while ago.
    My detector was installed very close to the A/C cabinet and 110 outlet for the A/C, and upside down, so it took a little bit of effort, but at the end of the day, the job is done.
    That battery lasted 4 seasons, including through several polar vortexes. I cannot complain.
  • During winter storage, we take out battery out and label the smoke detector with tape as a reminder.  New battery in the spring.
  • jkjenn
    jkjenn Posts: 6,424
    Good idea. I left the smoke detector cover open so that it would stick out to me.
    ScottG Posts: 5,688
    @jkjenn, I'm still not clear why the smoke detector's low battery alarm only started when you disconnected the T@B battery. That might be consistent with an alarm that was also hard wired (like in a house), but even those beep when the back-up battery gets low.
  • jkjenn
    jkjenn Posts: 6,424
    Coincidence....
