OMG! I just bought a new bigger and stronger tow vehicle so I could buy a T@B 400. I had a 2 door Jeep Wrangler (2000 lb tow capacity) which I used to tow my 320 (now for sale) so I upgraded to a 4 door Wrangler with a 3500 tow capacity. My nightmare realization is the max tongue weight is 350! The T@B website say dry tongue weight is 390! And wet is 400. Would it be dangerous for me to tow with the vehicle I just bought for this purpose???? Is there anything I can do to lessen this weight? Remove the propane tank? Take out the table? UGH!!!! Update: I think I can get a weight distribution system to help with the tongue weight. Just when I thought I knew everything...alas I'm still learning hahahaha. I'm ok with the overall towing capacity at 3500 pounds. I dont plan to lug a bunch of gear.
0 ·
2022 Ford F350 Tremor | 2022 Cirrus 620
There is a Canadian company that many Airstreamers swear by for their expertise in rigging hitches to pull things most
mortals wouldn’t think possible. Call them and ask for Andy. See what he says. Between Andy and Equalizer you will have your answer. Nucamp really doesn’t get involved in what you are asking about. https://www.canamrv.ca/towing-expertise/
Your challenge in in my opinion lies in the wheelbase. Let the engineers at the above two places guide you.
I think the 400 is likely out with either Wrangler, but I am sure somebody has done it, I think I saw a post here or on one of the FB groups. I was thinking that way too until I did a little research, sorry you are in the spot you are, but better to find out now before buying a 400.
You will be exceeding the tongue weight whenever the T@B is not 100% empty while you will be very near the JL's maximum towing capacity when T@B has typical camping stuff loaded. Expect you will also be operating the JL very near or over its GVWR when loaded and towing in "camping mode".
Jeep claims class II 3,500# towing
Real-world at sea level is 3,000#
Real-world at 3,000ft elevation is 2,730#
at 5,000ft 2,530#
at 7,000ft 2,430#
https://www.ajdesigner.com/apptrailertow/weightdistributionhitch.php
Maybe I could switch to this class 3 hitch so I can use the weight distribution hitch? I'm about to throw in the towel on this effort. Cry cry cry.
