Alde no heat but hot water
I have a new 2019 320s that we bought in December.  I have had the alde system running in our yard much of the time on electric, or both electric and propane without problem.  We have camped once and it worked fine on shore power.  We went on the second short trip this time without electric and the heat did not work on propane, however the water was hot.  I took pictures of the settings, making sure the timers were off, and priority set was to propane.  After we came home, the alde wont heat on electric either, only heats water up.   I checked the 2 15 amp fuses in the black panel and they were good.   Any help what to check?  Thanks, Rob
2019 320 s T@b white/ black
2008 Honda Ridgeline
