Please look to see if any glycol is on the floor under reservoir. Check levels after running it. The first time it circulates, you'll see the reservoir go low. That's the system filling up. Add more glycol after that happens. You'll see bubbles come through as the air is pushed out. Keep us posted!!!!mona said:Two things to check. First, check to see if the screw on cap is tight. If it’s loose, the glycol evaporated. Easy to remedy, just add glycol. Second, feel the bottom of the glycol tank where the connections are. There should be no chrystally or wet feel there or seen on the flooring under that area and the area where the Alde is located. That indicates leaking, and service is warranted.
Jeannie
