Microwave in Tab 400
norristm
Member Posts: 1
I am negotiating with a couple of dealers on a 2019 400 and getting conflicting info on the microwave. Does anyone a 400 with the factory install Microwave, and if so, is it hard wired into the inverter or does it only run from shore power? Also, do you know how many watts it is. Thanks!
Ours is 110 volt, plugs into an outet in the cabinet. Will have to pull the manual but I think it is 1200 watts.BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama -
It is possible that what they used changes or even the how they did it. The info might not be conflicting.
https://tab-rv.vanillacommunity.com/discussion/8230/t-b-400-2018-any-way-to-add-a-microwave#latest
I think it was discussed here. Specifically that the inverter was not powerful enough for the installed MV.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
