I was going around our new T@B putting screens on the various penetrations. I pulled the cap off the roof vent above the shower (is that the black tank vent?) and found this little gem already installed from the factory. I was puzzled because this appears it would work on the side vent (under the antenna port) as well, yet there is not a screen on that one.
I knew I'd never be able to explain what part I wanted to the dealer so I emailed NuCamp. Elsie said she was unaware that they were installing anything like this.
So, I ask the forum. Can anyone ID this screen so I can get another one for the side vent? It is flanged so it doesn't look like any of the Camco screens I've seen. And it's stuck in place with sealant so I don't want to pull it off to see if there is a number on the other side unless I really have to.
O, if it helps, this is a 2019 320S Boondock Lite.
The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. |
-REBEC OF GINAZ
2019 T@B 320S BD Lite, Jeep TJUR, Jeep JT
https://ventmastersstore.com/collections/small-round-vents
Not the same screen @targ depicted, but I thought I would share the site. I do not know the diameter of the roof A/C or side holding tank vent pipes, but they sell 1" circular screens. (The screens, "Maurice Franklin," are also available via Amazon.) I have been looking for something similar to use on the Alde vent for a cleaner look than the larger square Camco vent screen.
2" Round Open Screen Vent - tab style - Mill - Pkg of 6 https://www.amazon.com/dp/B01ED65HAY
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
