If anyone has taken their TAB400 2019 trailer through a CAT scale, or has put it on a trailer tongue scale, could you post your results here along with which options you have and whether you weighed it with full or empty tanks?
It would be of great help as there seems to be no clear answer from nuCAMP for tongue weights on the new trailers and most of us seem to be towing with vehicles that are expecting 405# with propane and batteries but dry tanks.
                F150 Pulling 2019 T@B400 BDL
0 ·
2013 Tundra TRD 5.7L
Massachusetts
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
The 400 is deceptive. It’s kinda portly for a small trailer. Not easily towed by vehicles without at least a 5000# tow rating.
No propane tank, all other tanks empty 460lbs.
Central Alabama
Bottom line is, the tongue weight is already considered somewhat excessive, so you could make some of the changes and have a lighter tongue weight that would still have you within proper ratios all around....I'm thinking.
I don't know if this is a possible solution but the published weight with propane is 405lbs and the actual weight is closer to 500lbs.
Thats more than a 20% difference.
I know there are probably reasons why my suggestion won't work. I hope that someone smarter than me finds a resolution.
Central Alabama
Central Alabama
FACTS as we believe them to be:
1) The 2019 T@B400 is built on a Norco BAL OEM trailer frame. It is made from (edit: not aluminum) high strength low alloy steel "C" channel that is 4-3/8" wide.
2) You can not use a weight distribution hitch on the Norco BAL OEM frame because engineers smarter than me said so. Has someting to do with it bending due to leverage forces but for now, we just can't do it.
3) Many vehicles with 5000# towing capacities appear to have a sentence, deep within their literature or owners manual that if you exceed X# of tongue weight, you need a weight distribution hitch. A 5000# hitch using a rule-of-thumb formula has a 500# or 10% tongue capacity.
4) The trailer as weighed per the data above is roughly 460# and with LB, trail mix, underwear, toothpaste and some water will push or exceed 500# on the tongue.
5) Tongue Weight refers to any weight in the vehicle that is between the axle and the end of the vehicle. So if you store backpacks, water jugs or anything in the rear portion, this counts towards the 500# of tongue weight.
6) You should have a margin of error on all your specification meaning you shouldn't load a 500# hitch with 500# but be something under that by a factor of perhaps 10%.
7) Engineers overbuild and underspec but while a military crane might be 40% overbuilt, a civilian device is likely on the order of 20-30% overbuilt. So, if you drive a 500# hitch with 500# of weight it won't fall off the car but it will impact the other systems especially if you are overloaded in other respects or under maintained on things like suspension & brakes.
6) We can't do anything about the tongue weight of the trailer because the 20# propane tank is already pretty small assuming you intend to boondock in it.
7) That leaves me at least with the belief that you need a 7000# capacity to safely own and operate the 2019 T@B400. This is a disappointment given the wast of money on my Equalizer hitch and Toyota TV was easily avoided but fortunately we have a forum that was able to step-in an clarify what we are all dealing with.
8) I'm going shopping for an F150. RAM is out because I need a flat floor for the dogs and Tahoe is out because the pricing is nuts.
9) If anyone is interested in a gently used 600# equalizer hitch, or a phenomenally maintained 2013 Toyota 4Runner with a recently installed transmission & engine cooler, let me know.
10) I'm going to enjoy my TAB and go camping!
I do think nuCamp needs to be involved. Their specs were off by 20%+.
2019 T@B 400 Boondock
I’m not sure #5 is quite correct. You may be mixing up tongue weight and payload. Tongue weight counts toward the tow vehicle’s payload, but I don’t think payload counts toward tongue weight. Tongue weight is governed by the hitch rating. And to confuse things even more, both payload AND tongue weight count toward the rear Gross Axle Weight Rating (GAWR). Thus, to be in full compliance, tongue weight has to be below the hitch rating, tongue weight plus cargo in the tow vehicle has to be below the tow vehicle’s payload rating, and EVERYTHING combined, including the vehicle, has to be below the rear GAWR.
#2 is also not necessarily correct. NuCamp seems to have reluctantly given an answer on this and they recommended only a bolt on WDH, however we know equalizer makes brackets specifically for the BAL Norco frames and we haven’t heard BAL Norcos a take on it.
i agree that with a 500 lb tongue limit you may be pushing it, but plenty of people are safely towing 400s with 4 runners and you can probably keep the tongue weight under 500 if you’re careful.
We may have heard from BAL Norco, depending on who put this sticker on the frame. The third bullet suggests that weight distribution hitches are acceptable, so long as you don’t use spring bars rated for more than 750 lbs. I haven’t read of anyone towing a T@B using a spring bar larger than 600 lbs.
The second bullet puzzles me. An F250 or a Ram 2500 is too big?
Central Alabama
Central Alabama
Central Alabama
