Tow sounds
forgalsus
forgalsus Member Posts: 10
I did a tab 320 S test tow today.   There was a lot of banging/rattling going on.   The dealer rep said it was normal.   Would appreciate feedback on what is considered normal hitch noises?   thanks
  • atlasb
    atlasb Member Posts: 584
    Our 320 also had hitch rattle.  there are several different hitch adapter/ anti rattle items and adding a little weight to the tongue weight helps.  Keeping the tow as level as possible also helps a little.  When we got our 400, no more rattle.
    Yes, movement of the bar in the receiver makes a racket - especially going over railroad tracks!  You can add a simple hitch tightener that helps a great deal.  Also, once you add some tongue weight, there will be less noise.
  • Homebodyatheart
    When your Tab is empty it does bounce around a bit. You can buy a Stowaway Hitch Tightener, Anti-Rattle Stabilizer for 2 Inch and 1.25 Inch Hitches to cut down on the noise. Personally I like the occasional clunk as it reminds me I’m towing!
    Once you add gear, food, propane, maybe water it will smooth out! Also putting weighty items on the floor in front of the axle helps.
    Go for it! 😊
  • mreric
    mreric Member Posts: 154
    if the noise is not coming from the hitch and draw bar movement than it might be something else.     i have a pretty quiet ride
  • Marceline
    Marceline Member Posts: 1,779
    Some people will tell you not to worry about it, but for me the sound of metal banging is the sound of metal fatiguing. There are a number of options:
    https://www.etrailer.com/search/Hitch+Tightener#/
  • forgalsus
    Thanks everybody!
    I like the rattling. It lets me know the T@B is still back there!  :-)
  • Sneakle
    Sneakle Member Posts: 131
    I put one wrap of duct tape on my hitch before inserting it in the receiver and it helped a lot. Just don't wrap so much that you can't insert it.
    Tab 320s Boondock
    TV: Toyota 4Runner
  • nbrandt
    nbrandt Member Posts: 65
    There is also something called the J Pin Hitch that you can get at etrailer that really quiets a hitch down.
  • 4ncar
    4ncar Member Posts: 1,072
    edited April 2019
    That’s the sound of your trailer still behind you! When it stops...you have bigger issues then just a noise!  :open_mouth:=)
  • tabiphile
    tabiphile Member Posts: 473
    Was that the name of a Beach Boys album?
  • Travelin3D
    Travelin3D Member Posts: 175
    Are you thinking Pet Sounds or Good Vibrations?
    Richie, Mickie and Satchmo
    2020 320S Boondock Lite (silver w/blue)
    2019 Subaru Ascent Premium
  • TabberJohn
    TabberJohn Member Posts: 588
    Looks like it only works with Draw-Tite hitches but is anyone using this gadget?
    https://www.etrailer.com/Hitch-Anti-Rattle/Draw-Tite/63080.html
    Watch on
    e of the videos.
  • PNWtabber
    PNWtabber Member Posts: 492
    Great discussion.  My son seems to think getting a solid hitch rather than the "tubular" one I currently have would reduce the noise.  Any thoughts on this idea?
  • VictoriaP
    VictoriaP Member Posts: 1,496
    I’d try a simple $10-15 hitch tightener before spending that kind of money.
    Two other options, the Curt RockerBall and the Convert-a-Ball cushioned ball mount, both claim to reduce the impact of trailer movement on the hitch, and therefore *may* reduce noise.
  • ChrisFix
    ChrisFix Member Posts: 743
    +1 on a hitch tightener. I use this one, but they mostly all perform similarly.
    https://www.amazon.com/gp/product/B01597QPL6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Nary a sound from the hitch receiver...
  • PNWtabber
    @ChrisFix -- I ordered one on Amazon today!  Thanks.
  • Ron
    Ron Member Posts: 137
    Also a vote for the hitch tightener.  My Wrangler Rubicon has a fairly big drop to the hitch with an angle to brace the flat metal plate the ball goes on to the square tube.  I had to cut a notch in the tightener plate to make it fit.  Works great and feels like a weight distribution hitch or an air lock pintle hitch.  No noise.  Also takes longer for someone to steal the hitch.
  • db_cooper
    db_cooper Member Posts: 749
    Another vote for a hitch tightener.  For those that like the sound as a reminder,  I'd rather eliminate a known noise so I can hear an actual problem noise.
