I did a tab 320 S test tow today. There was a lot of banging/rattling going on. The dealer rep said it was normal. Would appreciate feedback on what is considered normal hitch noises? thanks
Our 320 also had hitch rattle. there are several different hitch adapter/ anti rattle items and adding a little weight to the tongue weight helps. Keeping the tow as level as possible also helps a little. When we got our 400, no more rattle.
Yes, movement of the bar in the receiver makes a racket - especially going over railroad tracks! You can add a simple hitch tightener that helps a great deal. Also, once you add some tongue weight, there will be less noise.
When your Tab is empty it does bounce around a bit. You can buy a Stowaway Hitch Tightener, Anti-Rattle Stabilizer for 2 Inch and 1.25 Inch Hitches to cut down on the noise. Personally I like the occasional clunk as it reminds me I’m towing!
Once you add gear, food, propane, maybe water it will smooth out! Also putting weighty items on the floor in front of the axle helps.
Go for it! 😊
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
We got this hitch tightener. It's just a U-bolt & a plate, but very hefty & it really made the hitch quieter & solid feeling when going over bumps..
Mission Automotive Hitch Tightener for 1.25" and 2" Hitches - Heavy-Duty, Easy-Install, No-Rust - Made in The USA https://www.amazon.com/dp/B01597QPL6
We have the same device and I was pleasantly surprised at how eliminating those fractions of an inch of play in the hitch stopped the thunking noises and the constant "feedback" from the T@B. Feels much more stable and solidly connected to TV.
Great discussion. My son seems to think getting a solid hitch rather than the "tubular" one I currently have would reduce the noise. Any thoughts on this idea?
2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA "Blessed are the curious, for they shall have adventures.”― Lovelle Drachman
I’d try a simple $10-15 hitch tightener before spending that kind of money.
Two other options, the Curt RockerBall and the Convert-a-Ball cushioned ball mount, both claim to reduce the impact of trailer movement on the hitch, and therefore *may* reduce noise.
2019 320s BD Lite, white with blue (“Haven”) 2015 Subaru Outback 3.6r (unsafe 200lb tongue weight limit until 2020 models) 2020 Subaru Outback XT Pacific NW
After two years of looking and considering...finally the proud owner of a 2021 T@B 400 Boondock! 2023 Honda Ridgeline RTL-E with Redarc Trailer Brake Controller
Also a vote for the hitch tightener. My Wrangler Rubicon has a fairly big drop to the hitch with an angle to brace the flat metal plate the ball goes on to the square tube. I had to cut a notch in the tightener plate to make it fit. Works great and feels like a weight distribution hitch or an air lock pintle hitch. No noise. Also takes longer for someone to steal the hitch.
Another vote for a hitch tightener. For those that like the sound as a reminder, I'd rather eliminate a known noise so I can hear an actual problem noise.
Go for it! 😊
https://www.etrailer.com/search/Hitch+Tightener#/
TV: Toyota 4Runner
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
https://www.etrailer.com/Hitch-Anti-Rattle/Draw-Tite/63080.html
Watch one of the videos.
https://www.amazon.com/gp/product/B01597QPL6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Nary a sound from the hitch receiver...
